Yellowing headlihts?
Old Aug 5, 2007 | 05:36 PM
Cedric's Avatar
Cedric is infamous around these parts
Whats the cure?
Old Aug 6, 2007 | 10:15 AM
Triple B's Avatar
Triple B is infamous around these parts
I would like to know also......
Old Aug 6, 2007 | 09:14 PM
MoeMistry's Avatar
Premium Sponsor
It all depends on how deep the yellowing has gone. Sometimes if the surface is dried out, a good polishing will do the trick. There are some products out there that claim they will fix that problem. Could you post a picture?
Old Aug 6, 2007 | 09:31 PM
Zaks's Avatar
Zaks is infamous around these partsZaks is infamous around these parts
Moe is right... but I've found out that unless the yellowing is mostly stuff on the surface, sanding is the best option... I fixed tons of headlights so far with 600, 1000, 1500, 2000, 3000... (not necessarily starting with 600 or going in that order, but those grit values)... polishing almost always helps somewhat, but like I said, if it's bad enough, polishing won't fix it completely... post a pic like Moe said, maybe we can get an idea... get a close-up pic btw
Old Aug 7, 2007 | 07:45 AM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
yeah need to know as well. my Dad's e320 the lights are freaking yellow.
I should try to setsand them as suggested and/or try some cleaner. Just looking at them makes me mad. I can't believe MB quality on some stuff is Hyundai like. :-(
Old Aug 7, 2007 | 05:59 PM
Triple B's Avatar
The head lights / turn signals on my 7 year old truck are not to bad. Every time I wax the truck I put a coat of wax on the lights also. I am sure that has helped them over the years. I have never polished them. I will try that
Old Aug 8, 2007 | 07:19 AM
MoeMistry's Avatar
Premium Sponsor
Wax definitly helps. I always wax the headlights. Great technique.
Old Aug 13, 2007 | 10:37 AM
Triple B's Avatar
Thanks for the info guys......Yesterday while I was detailing my truck I polished and wax the head lights and they look great.
Thanks Again
Old Aug 18, 2007 | 09:20 PM
bruceinmiami's Avatar
bruceinmiami is infamous around these parts
are the 996 headlights glass or plastic?
Old Aug 20, 2007 | 12:13 AM
MoeMistry's Avatar
Premium Sponsor
Plastic lights
Old Aug 28, 2007 | 09:30 PM
82targa's Avatar
82targa is infamous around these parts
mine were pretty bad on my 996 and I used a sandpaper and buffing set i found on eBay and it worked awesome. It came with directions with the technique required and all the materials minus the high speed drill. That was about a year ago and i need another light buffing, but I haven't been using the protectant regularly. My rear lights are fine though. I think it has to do with the heat buildup inside the headlight. I'm sure you can probably cook hotdogs with the sun in a 996 headlight. I might just tint them with tint spray that I've seen around.
Old Aug 28, 2007 | 09:32 PM
82targa's Avatar
ALSO: Castrol SuperClean does an AMAZING job of removing the yellow color. Just spray it on and watch the yellow wash away.
Old Aug 29, 2007 | 12:54 PM
Triple B's Avatar
I would worry about that stuff getting on the paint
Old Aug 30, 2007 | 06:51 PM
82targa's Avatar
I use it to get the bugs off of my bumper with no problems. And the bumper has cheaper Diamont paint. Of course, you will have to rewax wherever it gets onto.
Old Aug 30, 2007 | 07:09 PM
MoeMistry's Avatar
Premium Sponsor
My sentiment exactly. Castrol is a VERY aggressive cleaner and I would be careful using it anywhere on the car. Stick with polishing.
