Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Pimping my garage
Old Jan 20, 2008 | 11:46 AM
  #106
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
Originally Posted by mountainC4
Do you have a General Contractor on the job? Good luck and hopefully it goes smooth from here on in!!
I am acting as my GC, and also doing most of the work with my own hands. Fire early and fire often seems to be the method required. Many areas of the house and garage are coming out a lot better because I am able to engineer changes on the fly as conditions change, just go into my house and start the CAD. Case in point is that while I always had a full basement in the house addition, I had to go through a hatch and crawlway to get to it from inside, or bulkhead from outside. When we raised the addition 2 feet to solve the water problem I designed a way to put in a stairwell and head off two of the floor trusses so I can now walk downstairs upright like a human. I am now 2+ years into this and hope to have the house ready for HVAC and electrical work in a few more weeks. Over the holidays I cut and installed 7 sets of stair stringers on the house. Only thing that has been done on the garage was to put an 18KW LP gas generator on a pad behind it. I have a big push on the house because I want to get back on the garage. Still no stairway inside, and the plywood deck on the second floor has only 7 nails in each sheet holding them in place. The trusses and plywood were a bit damp (also covered with frost) when I put the deck down so I could not glue them down the way I did on the house. Now that I have the ladder back in the garage and the wood has finished shrinking I can get up there and screw the sheets down. Deck feels slightly bouncy in some areas.
Another reason for a push is that I need most of the work done before autocross season starts. Got my priorities you know (wifey may have a different idea)
Old Jan 21, 2008 | 12:53 AM
  #107
petea4's Avatar
petea4 is infamous around these parts
Originally Posted by Mussel Kar
The garage floor plan has changed a bit. I relocated the lav upstairs to make more room for a lift with walking space all around it.
Moving the bathroom upstairs, great idea.
Old Jan 23, 2008 | 10:37 AM
  #108
Dino V's Avatar
Thanks for sharing your progress.
That will be one awesome garage when its complete.
Old Jan 23, 2008 | 11:24 AM
  #109
pattymcfatty76's Avatar
pattymcfatty76 is a jewel in the roughpattymcfatty76 is a jewel in the roughpattymcfatty76 is a jewel in the rough
any more pictures? this is going to be an awesome garage!
Old Jan 24, 2008 | 08:08 AM
  #110
silk55's Avatar
silk55 is infamous around these parts
Scruffster! long time no talk or see!!! glad to see your project is coming along mine is finally finished. got dig up my old post to put some pix up.
Old Feb 2, 2008 | 10:15 AM
  #111
Thero's Avatar
Thero is infamous around these parts
I've been watching this threed for a little over a year now (as a lurker) and now that I'm a member I just want to say that I cant wait to see the finished project.
Old Feb 18, 2008 | 07:42 PM
  #112
mountainC4's Avatar
mountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to behold
Let's pick it up Mussel car, more pics!!
Old Feb 22, 2008 | 11:08 AM
  #113
Smokinsupra95's Avatar
Smokinsupra95 is infamous around these parts
Looks awesome. Probably going to have to do something similar to this as my dad has just restored a 1946 Chevy COE and it doesn't even come close to fitting into the current garage!
Old Feb 27, 2008 | 05:35 PM
  #114
ap1dc5's Avatar
ap1dc5 is infamous around these parts
this is a work of art!!!!!!!!
Old Nov 16, 2008 | 12:58 PM
  #115
Mussel Kar's Avatar
Sorry, I'm not dead yet.
11 08 Progress report.
I spent most of the good weather of 07 at autocross and started back on the house late in November, that’s just the way it worked out. I built 7 sets of stairs in the house and just after New Years wifey could walk into the addition and walk upstairs too.
Spring of 08 I started back on the garage as I was mostly done framing the addition interior. First thing to do was to remove the construction door and put in a new steel unit. Space next to the garage also makes a nice parking place for the trailer. BTW, I am becoming VERY good at backing that sucker up. Just look back and check out the entrance to my driveway. No way to turn it around so I just back it in.
New septic system was put in last year and we have some crappy grass growing. Much better than the piles of dirt that were there,
Put a pad out back for an 18 KVA LP generator. Not shown is the 1000 gal LP tank. Very painful to fill that sucker for the first time. Got enough power to run the entire house, almost.
Next on the agenda was to frame the utility room under the stairs enough for the electrician to put the service panel and automatic transfer switch in place. I also cut and installed the stairs at the same time. I wanted a landing halfway up but I did not want to cut through the center wall, so no landing. I ended up maxing out the code for the rise and everything just fit in.
Panel on left, transfer switch on the right. Power lines also continue from here to the house, house has its own transfer switch.
And of course any open space quickly fills with junk. Most of this is construction related and will be disposed of when it is no longer needed.
When I framed the center wall I was not really sure where I would want any openings between the two sides, so I left some options open by heading off in a few areas. Back will most likely get a 3’ door. Center is unknown at this point. Front will also get a 3” door that swings away from the car to the left, location to be determined.
Back two openings.
Front opening.
And that is where she stands at the present. Only other thing I will do this year is rip off the garage door wood trim and replace it with solid PVC trim. PVC trim boards are white so I won’t need to paint them.
Old Nov 16, 2008 | 04:04 PM
  #116
R32Topgun's Avatar
R32Topgun is infamous around these parts
great cars and the garage looks almost perfect now its time to clean it up .
Old Nov 19, 2008 | 08:05 PM
  #117
mab badgerbimme's Avatar
mab badgerbimme is infamous around these parts
you should go with lift master side jack garage door lifts. would be much better in your application.
Old Nov 27, 2008 | 01:34 PM
  #118
GMS03's Avatar
GMS03 is infamous around these parts
not finish yet?
Old Dec 1, 2008 | 03:46 PM
  #119
Mussel Kar's Avatar
Originally Posted by GMS03
not finish yet?
I should be back to work on it in a week or two. I should be ready to turn the house over to subs by next weekend.
Old Dec 1, 2008 | 05:56 PM
  #120
1SICKLEX's Avatar
1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold1SICKLEX is a splendid one to behold
Thank you for the updates!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
