Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Cracked concrete slab in garage- how to move forward with 'nice' flooring?
Old Jul 7, 2007 | 03:49 PM
BrakeL8's Avatar
BrakeL8 is infamous around these partsBrakeL8 is infamous around these parts
Searched on here- figured I'd see if any of you have encountered cracks in your garage floor slab and how you've then 'fixed up' the garage/floor.
I figure to get any sort of protectant/seal down first these would need to be at a minimum professionally patched, and possibly a new floor poured?
Any advice would be appreciated- if tossing racedeck over the cracks would work this could certainly be the cheapest route to go.
Old Jul 9, 2007 | 12:14 PM
ag-Z06's Avatar
ag-Z06 is infamous around these parts
The previous owner of my home put down the rubber floor that comes in huge rolls, about 8' wide. I like it, as it is really easy to sweep out, can be hosed out if really dirty, and can be removed if required. Most of the race-deck flooring I've seen requires a lot of work to snap it all together. If the decking is not solid, spills would run through and require you to lift the floor to clean up.
I've seen the stuff at Costco now, and it's not too expensive.
Old Jul 9, 2007 | 08:43 PM
Secure's Avatar
Secure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud of
How bad are they? You can probably do it yourself if you want to spend the time. Home Depot has alot of products for concrete patching, etc.
Old Jul 9, 2007 | 08:47 PM
993inNC's Avatar
993inNC is infamous around these parts
I'm in the process of "remodeling" my garage and have a huge crack across my slab that'll need fixing before I proceed. The crack is wide enough that I'll probably have to grind it out and fill it back with expoxy concrete patch. I'm also trying to decide if I want to go the custom route and do the floor tiles in some sort of pattern. The other thing I am considering is having one of those truck bedliner products sprayed on the floor. It is apparently great for concrete and is slip resistant, easy clean up, good warranty etc.....
Old Jul 12, 2007 | 05:23 PM
BrakeL8's Avatar
thanks all for the thoughts/suggestions
cnebrask
Oct 3, 2024 08:19 PM
steve.rinaldi
Sep 5, 2015 06:52 AM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
murox
Aug 22, 2015 10:32 AM
DB IX
Aug 21, 2015 09:45 AM
