The Dymags finally came in
Old Nov 1, 2007 | 05:31 AM
brnsrgn's Avatar
brnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant futurebrnsrgn has a brilliant future
Are you sure? An older thread here detailed that the GT3RS wheels could be swapped onto the turbo with no need for spacers.
Old Nov 1, 2007 | 06:36 AM
GTS-R's Avatar
GTS-R is infamous around these parts
That is correct. However, Juan's dymags were made for the GT3, not the RS.
Old Nov 1, 2007 | 10:08 AM
Paris_CarreraS's Avatar
Paris_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the rough
Thumbs up
pics pics pics!!!!
Old Nov 1, 2007 | 11:14 AM
sharkster's Avatar
Originally Posted by GT3Ranger
Sorry my mistake, forgot to sent the pics:
http://picasaweb.google.com/whitneyd.../DymagWheels02
those are really neat Juan! Post pix when they're on
Old Nov 5, 2007 | 08:44 PM
RENNWORX GT3's Avatar
RENNWORX GT3 is infamous around these partsRENNWORX GT3 is infamous around these parts
The offset we use for the 997 GT3 is +58mm and on the RS we use +51mm so the RS would need a 5 to 10mm spacer if you want to use your GT3 wheels on the RS. THANKS FOR YOUR BUSINESS WITH WHEELS BOUTIQUE AND PLEASE SEND PICTURES ON THE CAR.
Old Nov 5, 2007 | 09:03 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
We want some pics of DYMAG wheels info is limited
Old Nov 5, 2007 | 09:53 PM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
I will plan to post pics of the GT3 with the Dymags mounted but right now the GT3 is laid up at Champion Motorsport. As I mentioned, the crank pulley became loose and undone causing the car to sverely over heat. Now I'm told that the pulley needs to come from Germany and the latest is they do not have any pulleys. The bull**** is piling on and my patience is coming to its limit. I can not get a substantive answer as to why this happened.
BTW luiscarlos on the 3rd reply of this thread there is a link to see pics I sent of my Dymags.
Cheers, GT3Ranger...Juan
Old Nov 5, 2007 | 10:25 PM
Brandon's Avatar
Brandon is infamous around these parts
those are nice. pm me pricing =)
Old Nov 6, 2007 | 09:27 AM
atomic80's Avatar
Are you sure? When I had GT3 wheels on my 997 Turbo originally I had to use 18mm spacers on the rear. 5/10mm doesn't sound like it'd be enough.
Old Nov 6, 2007 | 09:52 AM
Eric523's Avatar
Eric523 is infamous around these parts
Dymag is making them with custom offsets I believe, not stock GT3 offsets.
Old Nov 6, 2007 | 06:39 PM
luiscarlos's Avatar
Yes I saw the pics you post,I was referring to Dymag if you see his web site they have only a few pics of their wheels....
Old Nov 8, 2007 | 01:00 PM
ApeelinZ's Avatar
ApeelinZ is infamous around these parts
Included are a few pics of the Dymag wheel. The fronts are 19x9, rears 19x12. I was only able to weigh the front. It weighs 16 lbs. The look and finish of the wheels are outstanding.
Wow, only 16lbs for the 19x9's. I need a set of those for my RS4.
Old Nov 9, 2007 | 10:00 AM
tshih's Avatar
tshih is infamous around these parts
Nice wheels, what kind of tire mounting machine will dependably mount and dismount your tires without scratching or damaging the wheels?
Old Nov 9, 2007 | 11:02 AM
ApeelinZ's Avatar
Good Question.
Old Nov 9, 2007 | 11:45 AM
GT3Ranger's Avatar
I ordered the Dymags from my friend Ben at Wheels Botique. They are a first rate wheel and tire shop and I know and trust the quality of their work.
These wheels are outrageous and I can't wait to put them on the GT3 and re-dyno the car. I'm hoping for 10 to 12 rwhp gain. Acceleration, braking and handling should all be enhanced.
Compared to my present HRE 890R wheel the unsprung weight savings are 12lbs. per side up front and 15 lbs. per rear. Compared to the stock wheels that's 30 lbs. per front and 42 lbs per rear. That's based on the unsprung weight calculation (3 x's each lb. saved).
Good luck all, GT3Ranger...Juan.
