Proper GT3RS Break-in
Old Dec 26, 2007 | 07:19 PM
Marc's Avatar
Marc is just really niceMarc is just really niceMarc is just really niceMarc is just really niceMarc is just really nice
put in gear and go.
Old Dec 27, 2007 | 08:53 AM
G997's Avatar
G997 is infamous around these parts
A few hundred easy miles at first then run it anyway you wish.
Just make sure it's warmed up before you hit it...
Old Dec 27, 2007 | 08:59 AM
zbb0730's Avatar
zbb0730 is infamous around these parts
I know I'm in the minority, but, I did the proper break-in with my RS. I track it regularly and didn't want to take any chances. I've also had zero issues with my RMS...maybe there is a connection...maybe not. In any case, I would be the one guy that had an engine problem and P can test to see how the engine has been reved.
Old Dec 27, 2007 | 09:49 AM
TT Tommy's Avatar
TT Tommy is infamous around these parts
Originally Posted by toadinlaw
Its a race car
Exactly.
I don't think there are any Cup cars or RSR's that follow break in rules.
However... they rebuild often
tw
Old Dec 27, 2007 | 12:01 PM
Bill S's Avatar
Bill S has a spectacular aura aboutBill S has a spectacular aura about
Follow what is says in the owner's manual. That's the best advice as it's been reviewed by the people who design, build, test and litigate for the car. These high-revving close-tolerance engines need to be broken-in properly. I do that for all of my cars and they run beautifully for years.
Old Dec 27, 2007 | 12:08 PM
kaz555's Avatar
kaz555 is a jewel in the roughkaz555 is a jewel in the roughkaz555 is a jewel in the rough
You need to realize that the manufacturers write that stuff in the owners manual for warranty/insurance reasons. I do not think that 4000 revs is sufficient for break in period especially for a car that revs 8000+.
I think a proper break in period consists of revving higher in each gear, for example 2nd gear 3k RPM, 3rd gear 4k RPM. 5th Gear 5k, etc.
Thats what I read somewhere, I'll try to look for the site.
Old Dec 27, 2007 | 01:03 PM
Bill S's Avatar
Do you think Porsche doesn't want an engine broken in properly? They don't want to pay unnecessary warranty claims (e.g., low power, excessive oil consumption, flat spots, etc). Porsche knows the best, trust me. There's reasons to keep the revs down (and varied) for proper seating of piston rings against cylinder walls as well as other items.
Old Dec 27, 2007 | 01:07 PM
997gt3north's Avatar
997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice
Originally Posted by GT3Ranger
Coincidence that another reply mentioned an M5 because I to have an M5 and I babied my motor as recommended. I now now and been told you got to let her rip and loosen that motor up. My car has dyno'ed consistently lower than others.
My GT3 I let it rip from the beginning. I did not do anything stupid but I sure rev'ed and shifted at 7000 to 7500 rpm. The car has dyno'ed strong for stock (363 rwhp) and after FVD headers, 384 rwhp.
These cars are meant to be run hard. I know of individuals who have tracked the GT3 with only 200miles.
A little example, you build a race motor and it goes out and you run it ***** out. Maybe not a valid consideration but close enough.
Loosen that baby up!
GT3Ranger
drove it below 6000rpms for 200 miles and then 8400rpms every day since
my car has 12000miles on it and dynoes 389 to the wheels
changed the oil after 1000miles and then every 2500miles
Old Dec 27, 2007 | 01:09 PM
kaz555's Avatar
Here is an motorcycle example, frankly I do not know if this holds true for Porsche cars.
Although these pistons came out of engines which were raced for a full season, they weren't set-up with any special clearances or other preparation.
These engines were never worked on prior to being raced. They were totally stock as built by Honda.
The only difference was the break in method they used...
The one on the right was broken in as per instructions of tuner.
The one on the left was broken in exactly according to the owner's manual. The resulting leaky rings have allowed pressure to "blow by" down into the crankcase on acceleration, and oil to "suck-up" into the combustion chamber on deceleration.
Once again, not sure if this relates to Porsche vehicles.
Old Dec 27, 2007 | 01:15 PM
Simba's Avatar
Simba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud of
It applies to all piston engines. Specific to Porsche, the engines are run in at the factory through various cycles that do the majority of the ring seat.
Best thing you can do for the engine is flog the snot out if it right off the lot, and try to keep it in throttle or completely off throttle as much as possible for the first hundred miles or so.
adnanm3
Oct 25, 2016 08:38 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
