Installing Euro seats and Roll bar
Old Feb 27, 2008 | 01:40 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
Originally Posted by luiscarlos
Very good info thanks.
-If I disconnect the batt the airbags will still turn on ?
-I hope my car has the metal plates to att the roll bar.
1) if you disconnect the battery you are just taking a precaution of not doing something to get he air bag blow. when you replace the factory seats with racing seats at least in a 997 you are eliminating a thorax air bag that is in the seat, and you are eliminating a sensor in the pass seat to depower the bacg so you will get a bag warning light, and you will have to get a dealer to reprogram. you can do a search on rennlist, this is discussed. a guy named Mooty has the instructions to give to the dealer, as i had to, to turn off the bag warning.
2) all 996 and 997 have the necessary bolt holes, if your car had back seats it bolts to the old outboard set belt bolts if its a GT3 you lift the tape off as i showed in the pictures. I would do a search, everything you need to know is on this or Rennlist, I learned what i had to do from the list.
Its a beautiful thing. Good luck
Old Feb 27, 2008 | 03:46 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
subscribing for installed pics cant wait to see them in your car luis
Old Feb 27, 2008 | 07:34 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Today we took the seats and rear computer cover (where the RS logo) and made a pre installation of the roll bar and now I have some questions:
-Do I have to cut the computer cover to let the roll bar tubes pass ? or there is an specific carpet cover when you use the roll bar?
-I made some 10 x 10cm metal plates with 3 holes to connect the roll bar in the floor of the car since my car didn't had those plates welded in the floor.
The roll bar is a must for this cars it looks really cool
Old Feb 27, 2008 | 10:17 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
which rollbar did you get?
Old Feb 28, 2008 | 10:08 AM
luiscarlos's Avatar
Oem Rs
Old Feb 28, 2008 | 03:19 PM
how does the oem RS rollbar compare to the GMG?
Old Feb 28, 2008 | 09:53 PM
luiscarlos's Avatar
Señor Fernando I really don't know the GMG model but if there is and OEM I will prefer this one.
The rollbar is installed now it is very nice because it attaches to the rear shock towers and gives a lot of stiffness to the car,I had to made 4 10 x 10cm steel plates and drilled 3 holes each side and then used some nuts and bolts I made this to jump the welding since I don't know how to weld etc also used some Wurth black glue.
Had to cut the carpet this was scary but the results are super cool this is a must to any GT3 or GT3 RS...
Tomorrow the seats...
Old Feb 28, 2008 | 10:01 PM
im sure the pics will follow after the seat install right
Old Oct 29, 2008 | 08:53 PM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Originally Posted by toadinlaw
End result is worth it. It took me about 5 hrs to do seats, bar, belts.
Can your GT3 seats slide past your tequipment roll bar without stopping the seat.. unlike the stock seats that hit the lower section of the roll bar???
Old Oct 30, 2008 | 04:59 AM
gt3geoff's Avatar
gt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to behold
And where are the pics.
Old Oct 30, 2008 | 05:53 AM
sheim911rs's Avatar
sheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura about
I have the GT3 seats/tequipment roll bar, I'm 6'3" with a 35" inseam and my seat still has room to go back before contacting the bar.
Old Oct 30, 2008 | 09:57 AM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
Beautiful Pics.
Vellano Wheels
Other British Cars
Nov 25, 2015 08:57 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
