Erm, how to use battery charger on CGT?
Old Mar 2, 2008 | 01:19 PM
Val's Avatar
Val
Val is infamous around these parts
Ok, i finally connected the charger. How long should i leave it on?
Old Mar 2, 2008 | 04:59 PM
cmcjo's Avatar
cmcjo is infamous around these parts
I would say if after 2 days and it still has no power you may have to try a real battery charger connected to the battery.
Old Mar 2, 2008 | 05:05 PM
Val's Avatar
Val
Ok, great, thanks for help.
Old Mar 3, 2008 | 06:59 AM
Val's Avatar
Val
Ok, today i tried to turn on the car and the only light that came up was the backlight on the lights ****
Probably will try to open the boot today. Is it ok to connect battery charger to the fuse box under the dash to open the boot? Or i need to use another battery?
And yes, im a total noob when it comes to electronics
Old Mar 3, 2008 | 09:40 AM
Val's Avatar
Val
Ok did everything... Went smooth. Now the car has electricity will try to start it tomorrow.
Old Mar 3, 2008 | 09:42 AM
Val's Avatar
Val
As a side question... Does this look normal??
Old Mar 3, 2008 | 10:22 AM
Val's Avatar
Val
Here is a more detailed pic of the top wire
Old Mar 3, 2008 | 10:25 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
GUYS,
try owning a tow company that does aaa service calls to people who r having the same problem as u, with no forum to turn to. In addition u have to explain to all your employees the same thing u r explaining to each other, not easy to say the lease. The problem u r having is the same for 911's as well so its not limited to just the cgt. It really is tricky but if i could simplify it, follow this: Once u find the little red tab and pull it, connect a positive cable to it, then connect a negative cable to your door lock (the big u shaped thing bolted to the actual side of the car where the door locks to). then turn the power on ur portable pack and voila u should have enough power to open the hood latch. Hope it helps, if not ur guess is as good as mine, good luck
Old Mar 3, 2008 | 11:08 AM
cmcjo's Avatar
Originally Posted by dinorocz
GUYS,
Thanks. I think it is impotant to note that I needed to use a battery pack as you said or another battery since it didnt work for me using a battery charger.
Old Mar 3, 2008 | 11:09 AM
cmcjo's Avatar
I will take a look tonight and see if my car looks like that.
Old Mar 3, 2008 | 12:58 PM
Val's Avatar
Val
No, need! Some people already told me its not supposed to be there. Apparently its from a passport radar detector...
Old Mar 4, 2008 | 09:30 AM
Val's Avatar
Val
Ok, i charged the car... Started it... Left it to idle for like 15 mins... Switched it off... Tried to start again but it refused... Whats up with that???
Old Mar 4, 2008 | 09:50 AM
cmcjo's Avatar
Did you use the glove box trickle charger or did you use a regular battery charger?
I would suggest connecting a battery charger directly to the battery overnight and see if that works.
Old Mar 4, 2008 | 12:17 PM
Val's Avatar
Val
Yep, used the proper charger. Charged for about 8 hours, until current started to fall on the indicator. Maybe that wasnt enough.
Im trying to charge it no as well... For about 6 hours no and full day tomorrow. Im a bit hesitant to leave it overnight
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
