GMG or Sharkwerks bypass pipe?
Old Apr 10, 2008 | 11:28 AM
SirBells's Avatar
SirBells is infamous around these parts
Originally Posted by sharkster
Too funny!!! I need to put that in an ad
thanks, for such a great product...any word on he .8 kit
Old Apr 10, 2008 | 11:31 AM
chardonet's Avatar
chardonet is infamous around these partschardonet is infamous around these parts
I have GMG with the vacuum unplugged. The sound is fabulous.
When the decision was made to go with GMG, it was because GMG is only about 7 miles away from where I live. I communicated with Alex and Fabryce, and it was Alex that suggested that I support my local shop. Both are true professionals and gentlemen.
You won't go wrong with either of them in my opinion. Both are quality products. The only thing is to make sure the vacuum is unplugged!
Old Apr 10, 2008 | 11:39 AM
SirBells's Avatar
a gentlemen and a scholar.
Old Apr 10, 2008 | 02:53 PM
seefouress's Avatar
seefouress is infamous around these parts
Refresh my memory please. Does unplugging the vacuum do anything other than leaving the exhaust in sport mode all the time?
Old Apr 10, 2008 | 05:39 PM
chardonet's Avatar
Observations made by a Rennlister:
Sport off: idle - 4K RPM, the exhaust flows through all three mufflers. Above 4K RPM, the exhaust bypasses the two side mufflers and flows through the rear muffler only.
Sport on: at idle, the exhaust flows through rear muffler only. Above idle - 3K RPM, the exhaust flows through all three mufflers. Using light throttle from 3K - 4K RPM, the exhaust will continue to flow through all three mufflers. Apply moderate - heavy throttle above 3K RPM and the exhaust flows through the rear muffler only. Above 4K RPM, the exhaust flows through the rear muffler only.
Sport off/Sport on/Plug pulled: same sound over 4K RPM.
Sport off/Sport on: same sound 'just above idle' - 3K RPM.
Plug pulled: valves are open from idle - redline. The exhaust flows through rear muffler only. It is louder than either Sport-off/Sport-on in the 'above idle' - 3K RPM range. It's a purer sound.. no valves opening or closing, so no sudden changes in volume/tone. There is resonance/drone from 2K - 3K RPM, however.
Old Apr 10, 2008 | 07:27 PM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
Alex, have you thought about designing a bigger tip for the GT3? I would be interested. I'm sure Daytonaviolet would be also.
Old Apr 10, 2008 | 07:29 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
hopefully its already in teh works if not.. i prefer rounded 100mm tips.
Old Apr 10, 2008 | 07:39 PM
///M Kevin's Avatar
Fern, the silver RS at Anthony's shop had the GMG.
Old Apr 10, 2008 | 08:17 PM
FooFighterRS4's Avatar
FooFighterRS4 is infamous around these parts
I have the GMG bypass and have briefly heard the Sharkwerks bypass. Can't go wrong with either one. They are very similar. The GMG bypass has bigger tips. I think it's a little louder in non-sport mode but that may be my imagination. The GMG bypass lets out a little burble when you let off the throttle that I didn't notice in the Sharkwerks but I've been told is present (thanks Old Guy). All are pretty minor differences.
Old Apr 11, 2008 | 12:10 AM
sharkster's Avatar
Well we're enjoying it that's for sure on our car We've got 2-3 local cars lined up for the 3.8 surgery this summer
Old Apr 11, 2008 | 06:28 AM
seefouress's Avatar
Great explanation! Thanks for sharing that. Pulling the plug would seem to be a no brainer except for that drone you mentioned.
Saint Ari
Jan 17, 2022 09:22 PM
csmrx7
Jun 19, 2018 01:08 AM
kchu221
Oct 2, 2015 10:39 AM
RyanWoon
Sep 19, 2015 09:16 PM
Motams
Sep 15, 2015 08:59 AM
