who has re-geared their 3?
Old Aug 13, 2004 | 10:10 PM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
3's would be much more fun with lower gear sets -- has anyone?
Old Aug 13, 2004 | 11:52 PM
4Kurves's Avatar
4Kurves is infamous around these parts
I actually would like a slightly taller 2nd and 3rd gears. At Buttonwillow I run out of revs in 3rd several times and have breif stints in 4th in several places.
I'm curious Watt why you think the car is geared too tall? Or are just some gears too tall?
You definately have to work the gears in a 3 to get the best of the engine.
-Kevin
Old Aug 13, 2004 | 11:59 PM
watt's Avatar
kevin,
it seems obvious but maybe not, the gears are very tall. if you re-geared to a 6th gear redline at 150 the car would be faster in general usage. since most of us here have no use for 190 top speed, why not make the power lmore useful???
i wasnt referring to a particular gear matching a track corner. you could have a lower gear set Kevin, and then maybe your 3rd and 4th would serve better than the taller 2 and 3 you desire.
it comes to mind as the CS is geared so much lower, and i remember the Fun gain in lowering the gear set in my 2.4 S
Old Aug 14, 2004 | 12:04 AM
4Kurves's Avatar
You make a good point Watt - especially about the usability of a 190mph top end.
Ok, now you got me thinking - and I see your point about 3rd and 4th. I wonder where would one go to find a different gear set?
Old Aug 14, 2004 | 12:18 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Porsche Motorsport???
Old Aug 14, 2004 | 12:44 AM
Mr. RS's Avatar
Grand Pumba
Mr. RS is infamous around these parts
The only gear that can not be changed is first.
There is an outfit in the US somewhere that sells anygear you want.
Old Aug 14, 2004 | 12:47 AM
Greyghost's Avatar
Greyghost is infamous around these parts
Xico has had 3,4,5,6 re geared with substantial gains in acceleration. Top speed around 175. 150 would be enough for me but the 12-15K price tag is a serious deterent.
Old Aug 14, 2004 | 04:26 AM
Larry Herman's Avatar
Larry Herman is infamous around these parts
I agree with Kevin about running out of third a lot at tracks. It's unbelieveable with an 8200 RPM redline, but it does happen. As far as re-gearing lower, I hit 155 mph at several tracks around here, and at VIR with it's 1 mile straight, I have been told that the faster GT3s were hitting 185! 150 mph just won't cut it.
Old Aug 14, 2004 | 04:42 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
in all these cars it would be beneficial to have a taller 1,2 and possibly 3 and a shorter 6,5,4 and possibly 3.
3 is the swing gear that really depeneds on preference.
Old Aug 14, 2004 | 12:41 PM
cosmos's Avatar
cosmos is infamous around these parts
Red face 1st gear cant be changed
Ok, no problem, change the rear end, that way you lower all the gears. Just give the GT3 a lower final gear ratio.
Old Aug 14, 2004 | 01:56 PM
Z06's Avatar
Z06
Z06 is infamous around these parts
Stock GT3:
gear ratio mph@rpm
1 3.82 45@8200
2 2.15 80@8200
3 1.56 110@8200
4 1.21 142@8200
5 1.00 167@8000
6 0.85 190@7700
If you switch to a 4.00 R&P you get the following:
1, 3.82, 8200, 40
2, 2.15, 8200, 71
3, 1.56, 8200, 97
4, 1.21, 8200, 125
5, 1.00, 8000, 148
6, 0.85, 8000, 174
The factory Cup car looks like this
1, 3.15, 8000, 47
2, 2.00, 8000, 74
3, 1.56, 8000, 95
4, 1.31, 8000, 113
5, 1.09, 8000, 136
6, 0.91, 8000, 1
DEEPBLUE
Aug 29, 2009 04:14 AM
cgmeredithjr
Mar 13, 2009 07:43 PM
