996GT2 vs 997GT3
"The 6 GT2 on the other hand needs a good amount of suspension work to have the same kind predictability, compliance, etc... "
Not so sure about that. The right alignment set up on a stock 6-GT2 works very well and can provide 3-like handling. Although this certainly can be improved. It's in managing the power characteristics that changes the experience with the 2-quite a bit more demanding but the rewards are greater for some. That's why we say that both cars are the way to go, if you can swing it.
2 v 3
"While this wont require new dampers, you will need to swap the stock rear toe links (to control toe changes) and possibly the stock dog bones (to control camber changes under load)."
This was also true of the 6-GT3 but once done along with proper alignment the handling is sweet. I'm among those that thought the handling feel of the 6-GT3 was more visceral when compared to the next gen. While the 7 is better and faster overall, the 6 is the better deal and very close to the 7 in terms of performance. Good decision with yours, Colby.
pwdrhound
Aug 23, 2015 07:36 PM
