OBC showing 3 failures!!
Old Jan 3, 2009 | 07:01 PM
snowboarder54's Avatar
snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !
Question OBC showing 3 failures!!
What are the odds of this happening: TC failure-PASM failure and TPC inactive all at the same time??? Sounds like it maybe time for a 120 mile trip to the nearest dealer. I rather enjoy driving with TC off anyway. Anyone have this happen yet?
Old Jan 3, 2009 | 11:07 PM
Cabcar's Avatar
Cabcar has a spectacular aura aboutCabcar has a spectacular aura about
I had that happen when we took of the steering wheel direction sensor to put on the OMP steering wheel. Apparently the computer uses the directional information for a lot of calculations. I hope it is something simple like a loose wire or something....
Old Jan 6, 2009 | 03:35 AM
997GT3NM's Avatar
997GT3NM is infamous around these parts
Did you disconnect the battery? If you do, then you will get the TC and PASM for sure every time, and they go away in less than a minute after you drive off. As for the TPMS, I can't remember if that one also goes off, buy maybe it just needs to be reset or your pressures checked.
PV=nRT.
Sep 9, 2022 06:06 PM
pwdrhound
Sep 13, 2016 10:44 AM
MadWhip
Midwest
Sep 10, 2015 08:24 AM
JSF721
Detailing
Sep 8, 2015 07:57 AM
