Rotor replcment at what thickness?
Old Mar 18, 2009 | 09:44 AM
bsavino's Avatar
bsavino is a jewel in the roughbsavino is a jewel in the roughbsavino is a jewel in the roughbsavino is a jewel in the rough
Also rear brakes squeeking like crazy??? Why? Rotors too thin???
Old Mar 18, 2009 | 09:50 AM
sharkster's Avatar
I doubt it unless you've got a lot of track days and/or mileage racked up? Any sign of hairline cracking etc...? They are supposed to squeal and will do so That part is normal....
Old Mar 18, 2009 | 10:06 AM
bsavino's Avatar
Lots of track days, cracks starting to form and yes the squeek was there but lately very very load...its like my pagid race pads are on there...what do you look for the rotor thickness or the cracks or both?
Old Mar 18, 2009 | 11:01 AM
sharkster's Avatar
Oh i see... ok well see how much of a lip there is? I'm on the road today and using an iphone so I'd need to ask James on the rotor thickness but again check how much of a lip you've got...
Old Mar 18, 2009 | 11:34 AM
bsavino's Avatar
There is a little lip, i can put a micrometer on the rotor...
Old Mar 18, 2009 | 11:54 AM
bsavino's Avatar
Found some specs on renntect for rotor thicness fyi
wear limit rear: 22.00 mm ; front 26.00 mm
new rear 24 mm; front 28 mm
does this sound correct???
Old Mar 18, 2009 | 11:58 AM
bsavino's Avatar
Strike that...those are for the 996 brakes
for gt3 should be
new: Front 34 mm; rear 28 mm
wear limit: Front 32 mm; 26 mm
sorry for the confusion
Old Mar 18, 2009 | 12:27 PM
sharkster's Avatar
for gt3 should be
Ah.. that sounds better Post some pix of your rotors as well... Sounds like it might be time to replace them.... You can get slotted ones that should last you longer at the track.
Old Mar 18, 2009 | 12:30 PM
bsavino's Avatar
Ill mic them and let you know, thanks,
Old Mar 18, 2009 | 01:50 PM
vividracing's Avatar
New GT3 front and rear 2pc Brembo rotors available from Sharkwerks or Vivid Racing. If you upgrade your cracked and haggard rotors to these, you will not be replacing or having pad wear issues for a long time. Put some Pagid Yellow on there and you will be very happy.
http://www.vividracing.com/catalog/a...+rotor&x=0&y=0
Old Mar 18, 2009 | 08:36 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
I picked up the brembo 2pc rotors from dan at vividracing and they are the real deal. Havent had a proper track day yet as VIR was rained out last weekend, but I'll be hitting up NJMP Thunderbolt on Saturday to finally see how they are on the track.
The limited track time in the wet that I got at VIR brakes were actually the area where the car felt the most comfortable.
https://www.6speedonline.com/forums/...pc-rotors.html
I'll update with a review after Saturday
Old Mar 18, 2009 | 09:58 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Are they standard cast iron rotors or PCCB?
Old Mar 18, 2009 | 10:05 PM
sharkster's Avatar
he was saying standard hence we're saying normal
Old Mar 18, 2009 | 10:07 PM
Alex, well depends on whos standard
For some of us standard might be the PCCB, Its a matter of perception hahah.
But I see that he was refering to the cast irons.. LOL
Old Mar 18, 2009 | 10:10 PM
sharkster's Avatar
True dat! I love my PCCB's....
