997 GT3's - What tire sizes do you run on your 18" wheels?
Old Mar 23, 2009 | 08:23 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
It depends on the tire also, I just bought some OZ racing rims 8.5x18 12x18, I went with Nitto NT-01 and 245/40/18 and 315/30/18 is the closest I could come to a match. Note that the Toyo makes an R888 that is 335/30/18 which is a closer rolling diameter to the 305/30/19 than the 315/30 but Nitto does not make that size. If I was running triple 8's I would go with the 335. on the otherhand if you have a bit of a push in your car then go with the small rear rubber.
Old Mar 23, 2009 | 09:46 PM
996toomey's Avatar
996toomey is infamous around these parts
Did the OZs arrive? I am waiting anxiously for some photos and a report.
Old Mar 23, 2009 | 10:11 PM
lawjdc's Avatar
lawjdc is infamous around these parts
Originally Posted by Verde
Yes, I had heard 315/30/18's for the rear. Is that right? I'd want to match (and if not, just barely exceed) the OEM tires I have which are the 19" 305's.
315/30 x 18 R6 Hoosiers are slightly shorter, but wider than the OEM 19" 305's. If your car is a 997 C2S, the Hoosiers will look smallish. With the GT3, they look perfect at the proper ride height.
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
