GT3RS Spoiler
Old Jun 19, 2009 | 05:22 AM
camhabib's Avatar
camhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond repute
GT3RS Spoiler
I'm thinking about putting a GT3RS spoiler (aka this one: https://www.6speedonline.com/forums/...rs-decklid.jpg ) onto a C4S of mine that is soon to arrive.
1) Will it fit without any major redesigns or modifications?
2) What would I have to stick on the front bumper to complement the rear spoiler in terms of down force?
3) How much are we talking about for OEM and where to pick one up? I guess I would need the entire assembly, vs just the blade. Thanks.
Old Jun 19, 2009 | 06:53 AM
sws1's Avatar
sws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of light
North of $10k. SOmeone was just selling one.
Old Jun 19, 2009 | 07:59 AM
camhabib's Avatar
Do you remember how much it was going for? I wanted to add one, but not badly enough to spend $10k on one.
Old Jun 19, 2009 | 08:49 AM
Smind's Avatar
Smind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud ofSmind has much to be proud of
It will not fit without modification. Your airbox's intake and the GT3's are different. The underside of the decklid is different. Your best bet is to go with a replica from MA Shaw. He can affix the proper underside to the GT3-style decklid, making the installation plug and play.
Old Jun 19, 2009 | 01:41 PM
camhabib's Avatar
Thanks for the reply. Is there any way of using a decklid designed for the C4S (from aero kit or other) and mounting the GT3RS wing onto that? If the MA Shaw is a replica, it must use the same mounting points.
Old Jun 19, 2009 | 07:38 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
good question. i believe ma shaw made there molds from a 997S (underside) and then made the molds for the RS decklid (top side) and put them together. now you'll have the RS declid look but the underside which supports the 997S intake and fan locations.
if you really wanted an oem application, the only other way is to purchase the oem RS decklid and then bake it. baking it will seperate the botton half from the top half. then you would also have to do that to an oem 997S aero decklid and then glue them back together. but this will be very costly.
your best bet is to go with the MA Shaw kit with the right body shop, these replicas can be prepped/painted to look and fit like OEM.
markj
Oct 7, 2015 01:24 PM
viprklr
Sep 27, 2015 11:44 AM
