can you switch steel and pccb rotors?
Old Nov 19, 2004 | 11:20 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
can you guys confirm whether one could fit pccb rotors in steel brakes to save weight on the street??? [switching back for track use].
i was told by a usually reliable mechanic today that one could just switch rotors back & forth
i know eveyone with pccb rotors in good shape wants to sell them cheap, just to clear out the garage.....
Old Nov 19, 2004 | 11:32 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
The fronts are a direct swap... the rear needs different calipers due to the different diameter of the rear rotor. (330mm steel v 350mm PCCB) It may be possible to fit a 10mm spacer to use the standard rear calipers with the PCCB rotors.
Old Nov 19, 2004 | 11:59 AM
dwishen's Avatar
dwishen is infamous around these parts
Watt,
Did you buy Scott's GT3? If so, any big plans for it (i.e., will it be the toy and the CS your DD)?
-DW
Old Nov 19, 2004 | 06:19 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
Re: can you switch steel and pccb rotors?
Fronts only as Sloth already mentioned.
Old Nov 19, 2004 | 07:16 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Yes, Just the fronts are direct swap and rear calipers have to be changed.
Old Nov 20, 2004 | 09:37 AM
4Kurves's Avatar
4Kurves is infamous around these parts
Wouldn't you hav eto be concerned about the pads as well? I thought the PCCB used different pads (the black with yellow strip that I am now using) then the steel brakes.
Although I guess as long as you under there changing the rotors.....
Old Nov 20, 2004 | 11:21 AM
JASCLASS's Avatar
No, The yellow pads on the GT2 PCCB are the same as the steels on the GT3.
Old Nov 20, 2004 | 11:37 AM
MetalSolid's Avatar
MetalSolid is infamous around these parts
The pistons on the PCCB are different, ceramic backed I believe, to prevent heat transfer to the fluid.
Rguy
Apr 12, 2020 11:11 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
