FVD Brombacher - 2010 GT3/RS Exhausts
I have been asked several time's for what exhaust products we have for the 2010 GT3/RS. Perhaps my initial post was not very clear so I apologize. All of the systems below are available for the 2010 GT3/RS.
What do Porsche Super Cup, Carrera Cup Deutschland, ADAC GT Masters, ALMS / LMS, VLN / BF Goodrich, FIA GT and Rallye Meistershaft have in common with FVD Brombacher? Many of the GT3’s running in these series have exhaust’s designed and produced by our new manufacturer from Germany, M&M. Oh, I also forgot to mention that they make the Cup/S and RSR systems’ for non other than Porsche Motorsports.
Now all of that experience, design prowess, power and reliability can benefit you on local track’s across the U.S. The FVD “Brombacher” exhaust line is the most comprehensive in the industry. Simply put, we can cater to just about any exhaust requirement that you have for your 2010 GT3/RS. The “Brombacher” line now offers some of the lightest, most powerful and most reliable exhausts for track day warriors like yourselves.
Brombacher is proud to announce these exhaust options for your GT3/RS:
Here is the entire line for 2010 GT3 and GT3 RS…
Center Muffler Bypass 997 GT3/RS "Brombacher " with Tips
- + 4 crank hp & + 3 crank torque
- 2 1/2" tubing (63.5mm) straight through design for max. power
- Weighs 8.3 lbs. (3,7 Kg), 11.7 lb saving’s over stock center muffler.
- T 316 stainless steel for improved durability over T 304
- 2 x 2.5"(63.5mm) round tips
- Includes all necessary clamps and mounting brackets
- Made in Germany
- 98 dB
- Intoxicating growl at idle, partial throttle and wide open throttle
- No interior resonance
- No DME programming necessary, does not alter emissions, 50 state legal in the U.S.
More info...
“BROMBACHER” 997GT3/RS Racing Exhaust System
- + 25 crank hp & + 25 crank torque
- 200 Cell high flow, tri metal german HJS sport catalysts
- 2 3/4" tubing (70 mm) straight through design for max. power
- Equal length header set up with merge collector for maximum torque gain
- Weighs 42 lbs. (19 Kg)
- 44.5 lb (20 Kg) saving’s over stock system!!
- Reuse’s factory center muffler for backpressure and resonance dampening.
- Includes all necessary clamps and mounting brakets
- Made in Germany
- 108 dB
- Reuse’s factory tips or larger aftermarket tips
More info...
"Brombacher" Race Exhaust System 997 GT3/RS Super Sound with RSR style tips
Picture's are not currently available but this system will be similar to the above system, but it will bypass the center muffler and end with RSR angle cut tips...
- 2 3/4" tubing (90 mm) straight through design for max. power
- Weighs 42 lbs. (19 Kg) THIS WILL BE THE LIGHTEST STAINLESS SYSTEM IN TH LINE !!**
- 44.5 lb (20 Kg) saving’s over stock system!!**
- Bypass’ center muffler with straight pipes
- Made in Germany
- 110 dB (Not for faint of heart!!!)
** Currently in the last phase of production, may be lighter!!
More info...
“BROMBACHER“ Sport Muffler for 997GT3/RS (Sound Version)
- + 10 crank hp & + 10crank torque
- 2 3/4" tubing (70mm) straight through design for max. power
- Weighs 28 lbs. (12.7 Kg)
- Replace’s stock side muffler’s and stock center muffler
- 36 lbs (16.3 Kg) saving’s over stock system!!
- 2 x 3.5"(90mm) round tips
- Made in Germany
- 105 dB
- Intoxicating Cup Car growl at idle, partial throttle and wide open throttle
More info...
“BROMBACHER" Sport Muffler for 997GT3/RS (Sound Version) in Titanium
- + 10 crank hp & + 10 crank torque
- Weighs 17 lbs. (7.7 Kg)
- 47 lbs (21.3 Kg) saving’s over stock system!!
- 1,000 degree celcius titanium
- Made in Germany
- 105 dB
All titanium system’s NOT created equal…the titanium that we use is the highest grade available. In essence it can handle up to 1,000 degree’s celcius. Why is that important? Many tuner’s use lower grade titanium in order to save cost’s. Unfortunately, low grade titanium oxidizes with oxygen overtime and with the high heat that a high revving Porsche’s can produce the system’s become extremely brittle. Brittle systems will crack in time.
More info...
“BROMBACHER" 997GT3 Cup Exhaust without headers
- + 15 crank hp & + 14 crank torque
- 100 Cell high flow, tri metal german HJS sport catalysts
- Weighs 55 lbs. (25.3 Kg)
- 2 x 2 3/4"(70mm) round center exit tips
- Made in Germany
- 98 dB (can be ordered in different dB to comply with your local track)
Note: Any of our Cup Car exhaust systems can be ordered with headers, you can also order just the side mufflers with or without center exit pipes. Kindly ask your sales person for more details.
More info...
“BROMBACHER” 997GT3 Cup S Exhaust in Titanium without headers
- 15.5 lb weight savings over stock
- 2 x 3.5"(90mm) round center exit tips
- Made in Germany
- 98 dB (98dB at idle and partial throttle, builds to 100dB at WOT)
Note: Header's can be ordered seperately, this system is not available online, kindly ask your sales person for more details.
“BROMBACHER” Exhaust System for 997 GT3/RS (Sound Version)
- Weighs 71 lbs. (32,2 Kg)
- 15.5 lb (7 Kg) weight savings over stock
- Made in Germany
More info...
“BROMBACHER” Exhaust System for 997 GT3/RS (Sound Version) with RSR style tips
- 2 x 2 3/4" (70mm) angle cut RSR center exit tips
- Made in Germany
More info...
"Brombacher" Exhaust System for 997 GT3/RS TÜV (Quiet Version)
- Equal length header set up for maximum torque gain
- Weighs 71 lbs. (32,2 Kg),
- Made in Germany
- Intoxicating growl at idle, partial throttle and wide open throttle while remaining within the dB limits of the TÜV.
More info...
"Brombacher" Titanium Race System (Sound Version) for GT3/RS
- + 20 crank hp & + 19 crank torque.
- Complete System in Titanium (without Side mufflers)
- 200 Cell high flow, titanium tri metal german HJS sport catalysts
- 2 x 90mm tailpipes.
- Weighs 28.6 lbs (13kg)!!!
- 1000 degree Celcius, high grade Titanium material
- 105-107 dB
- Includes quick release clamps
- Made in Germany
- Modular design for 100 cell, 200 cell or bypass use
- No DME programming necessary.
The titanium tips can be ordered “flamed” which exhibit’s the blue tint.
All titanium system’s NOT created equal! Brombacher exhausts systems are nearly 40% lighter compared steel, manufactured from the highest grade titanium available and are tested to ensure heat loads up to 1,000 degree’s celcuis. This is critical as other exhaust manufactures use a lower grade titanium in order to save cost. Unfortunately, low grade titanium will oxidize overtime and become extremely brittle. This brittle condition will eventually lead to cracking due to the high heat that the high revving Porsche engine produces.
More info...
"Brombacher" Titanium Exhaust System for 997 GT3/RS (Sound Version) with side mufflers and titanium blue flamed tips.
- 1,000 Degree Celcius Titanium
- Weighs 48 lbs. (21,9 Kg),
- 38.5 lb (17,5 Kg) weight savings over stock
- 2 x 3.5"(90mm) blue flamed titanium center exit tips
- Made in Germany
More info...
Feel free to pm or email me for further details...
Rhonda@fvd.us
Thanks,
Rhonda
- 15 different exhaust product’s in the “Brombacher” line for GT3/RS/Cup/CupS*
- Exhaust systems can be ordered either in titanium or stainless steel.
- We offer 3 different HJS catalytic cores 50, 100, or 200 cell cats.
- We have a wide range of decibel options that can suit your local track requirements.
- GT3 exhaust tips can be ordered in GT3 street format, Cup S or RSR style.
* 12 are currently available, 3 are currently in initial stage’s of production and are for the U.S. market only. We will keep everyone posted.
- Made in Germany
- 98 dB
More info...
- Made in Germany
- 108 dB
More info...
- Made in Germany
More info...
- Made in Germany
- 105 dB
More info...
- Made in Germany
- 105 dB
More info...
- Made in Germany
More info...
- Made in Germany
- Made in Germany
More info...
- Made in Germany
More info...
- Made in Germany
More info...
- 105-107 dB
- Made in Germany
More info...
- Made in Germany
More info...
Rhonda@fvd.us
Thanks,
Rhonda
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Rhonda Roxburgh
+1-954-571-2050 x 1
Lowtush
Jan 25, 2022 10:48 AM
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
