In car camera recommendations
SubscribeI am in the market to buy a new In car camera system. I wanted to get everyones opinion on which one you guys would recommend and what you wouldn't recommend. I want to spend around $800 I am willing to go up to $1000 if need be. Is that doable? I would like a two camera system if possible and in HD? Your opinions would be greatly appreciated. Thanks Guys
- Mark
- Mark
Quote:
Thanks for the quick response. Do they have the regular screw in type base on those so I can use my roll bar mount? I checked out there web site. I watched a few video's. It is priced competatively so I could buy two or three. I like this one so far. Originally Posted by Harold
The Go Pro Hero camera is cheap and acceptable for the price. It also records in HD..... check out their website.
- Mark
Quote:
- Mark
No, the camera is housed in a special case that slides into a Go Pro specific mount. You will need to buy the Go Pro roll cage mount as a result.Originally Posted by LSXRX7
Thanks for the quick response. Do they have the regular screw in type base on those so I can use my roll bar mount? I checked out there web site. I watched a few video's. It is priced competatively so I could buy two or three. I like this one so far. - Mark
Quote:
If you buy the GoPro HD Hero Motorsport version, it already comes with it I believe.Originally Posted by Harold
I have the GoPro HD mounted to my roll bar. The cost is under $300 and the video quality is great (1080). It comes with several mounts but NOT a roll bar mount. The roll bar mount is an additional $29 but worth having. If recording in HD the file sizes are large (2-4 gb per 20-40 minute driving session) so a big SD card is helpful. I have a 32 gb card which is more than enough. Battery life is about 2.5hrs between recharges, so you want to shut the camera off altogether between driving sessions.
I am running Pikes Peak and I tested the Go Pro when I made my notes. Incredible! I am buying a second one for the race. 1 in and 1 out. Its the onlt camera that I have ever seen with only 2 buttons!
Best set-up (mounting options, video quality, camera size, etc.) is Contour HD 1080 in my opinion.
http://vholdr.com/contourhd/helmetcam
See some examples of Videos I did using 2 cameras in my Cup Car (look at it in 1080p and in full screen mode to really enjoy the quality):
https://www.6speedonline.com/forums/...e-hot-lap.html
https://www.6speedonline.com/forums/...challenge.html
https://www.6speedonline.com/forums/...w-cup-car.html
Thanks for all the replies everyone. There is some great information here. Does the Contour HD come with the tripod hole so I can mount to all the different mounts I already have?Originally Posted by GT3Techno
Best set-up (mounting options, video quality, camera size, etc.) is Contour HD 1080 in my opinion.http://vholdr.com/contourhd/helmetcam
Quote:
Just got this one too, easier to use then my gopro and better audio quality. Gopro will make a great paperweight.Originally Posted by sin911
I bought Contour HD, great camera and great price!
