lowering RS
Old Oct 22, 2010 | 07:20 AM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
lowering RS
Tomorrow i want to lower 3 turns rear and 2 turns front,I am not going to align but I can move the rear toe a little bit.
My question is will I loose or gain toe in the rear by lowering the car.
I think i will loose rear toe.
Old Oct 22, 2010 | 09:08 AM
10GT3's Avatar
10GT3 is infamous around these parts10GT3 is infamous around these parts
recommend lowering, align and corner balance. just lowering will directly effect alignment (camber) and without alignment you will not know where you are. i lowered my front end 10mm and rear 13mm. big change in numbers. realigned and all is well.
Old Oct 22, 2010 | 09:48 AM
luiscarlos's Avatar
Yes correct,I always align and corner balance with strings etc
This time I don't have the ramp so it will be provisional...
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Stuart@VelocityAP
Sep 23, 2015 05:30 PM
