PZero Tire Pressure?
Old Oct 27, 2010 | 03:31 PM
rditri's Avatar
rditri is infamous around these parts
Can anyone out there running Pirelli PZero's tell me what cold tire pressures you're running?
Old Oct 28, 2010 | 03:31 PM
Newman's Avatar
Newman is a jewel in the roughNewman is a jewel in the roughNewman is a jewel in the rough
I am running 29 psi and 31 psi as recommended in the owner's manual on the PZeros. I asked the Service Manager when I switched over from the Michelin Pilot Sport Cups if I should raise the pressure to what my 2007 Turbo ran; he told me to stay with the same pressure as the Michelins. I never fully accepted that answer, but I have 3,000 miles on the PZeros and no unusual wear. I'll be interested to hear if anyone else has better information.
Old Oct 29, 2010 | 12:20 AM
torched gt3's Avatar
torched gt3 is infamous around these parts
I'm running 2.0 bar front 2.1 bar rear as stated in the owners manual great tires!
Old Oct 29, 2010 | 02:20 PM
rditri's Avatar
Thanks. That's what I've been running. Problem has been when I run rear pressures under 34 lbs my TPMS goes off and warns me I'm under inflated. Annoying, but I just ignore it. Probably a bad sensor? I've had to replace one before on my C4S.
Old Oct 29, 2010 | 02:29 PM
Newman's Avatar
I have never had that problem - in the cold weather in the Northeast, I've had my pressures drop to 27/29 psi without any signal from the GT3s TPM system. Your dealer may need to reset your computer; usually that low pressure signal only goes off when you are 5 psi low - my 2007 TT was set to 34/39 psi so at 34 psi in the rear tires l would get a low pressure signal.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Jeanmarcboilard
Aug 27, 2015 06:51 PM
The Oss
Aug 24, 2015 08:19 PM
