What pressures do you run for street?
track pressures are totally different than for the street...agressive track driving will raise the cold pressure 8 to 10 pounds and when street tires get around 40 psi hot they lose grip so cold pressures for the track start out underinflated to allow for 8-10 pounds increase...there is nothing wrong with using the recommended cold pressures for street driving because unless you are Jeremy Clarkson spirited driving is unlikely to exceed 40psi
starting cold track pressures will depend on the track conditions/ambient temperature and your driving style...also depends on your experience level because when you first start out you won't be putting that much heat into your tires...if it was a normal day with 70deg temps I would start out in the morning with 28-30f and 30-32r and run 4 or 5 laps and come into the pit and check pressures and go from there..should give you a good baseline...finish the session and check them again as soon as you pit and drop them to your desired hot pressure if they exceed your target..best to not exceed 38-39f and 39-40r hot...check again after each session and adjust if necessary
+1.. Sounds like the most sense to me.
I use the pressures stated in my Porsche owners manual. If I remember correctly for the RS its (cold) 29 front 33 rear. There is a label somewhere on the door frame that clearly states it. 30f/34r hot seems too low but without knowing the ambient conditions, etc, impossible for me to judge. That's why cold starting pressures are typically used as the starting point for reference.
For the MPSC and my RS, with a nitrogen fill, I start cold with 29f/31r and adjust from there. With compressed air fill I start lower, usually 28f/28r. I try to end up at 34-36f/38-39r (definitely below 40) with my set up. There are a lot of variables but those are reasonable reference points as stated by others.
Inside the door
For my 2007 GT3 the factory recommended pressures (as shown on the label inside the driver's door) are 29F and 33R.
My car came with the Pirelli P-Zero Corsa's.
Mr. B
Mr. B
wonder why the vast difference in factory pressures?
