Difference between TT and GT2 Trans?
Old Dec 13, 2010 | 06:52 AM
il nino's Avatar
il nino is infamous around these partsil nino is infamous around these parts
I recently sold my 08 TT with a short shifter installed and bought an 08 GT2 and the trans seems much stiffer when making a shift. It is smooth but it requires a real firm action to get it into gear, as if the synchros where different for a racing environment. Is anyone familiar with this difference?
Old Dec 13, 2010 | 08:08 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
It is due more to the clutch than tranny. TT has the accumulator....hydraulic assist. Makes the pedal feel light. GT2 is manual. More pedal force required...."feels" more manual...you feel more "engaged." Make sense?
Old Dec 15, 2010 | 11:25 AM
il nino's Avatar
The difference in sensation is not due to the difference in the clutch. The clutch is definitely more mechanical feeling without the hydraulic assist. When the clutch is fully disengaged, there is still a more mechanical feel to the shifter. I don't think that it is in the linkage but I was wondering if the synchros are different or if the gears are cut differently to make them stronger for more aggressive driving.
Old Dec 15, 2010 | 02:53 PM
bbywu's Avatar
Excluding the clutch/flywheel assembly, PET lists two different transmission designations for the 997TT and GT2.
Gear ratios are definitely different...3.15; 1.89; 1.40; 1.09; 0.89; 0.73; 3.44
Old Dec 16, 2010 | 09:26 AM
petey01's Avatar
petey01 is infamous around these parts
Doesn't the GT2 have a "short shift" or "sports shift",which has a shorter movement than standard but also,consequently a heavier feel?Don't some other Porsches also have a sports shift option,which is shorter,but also heavier?
Old Dec 16, 2010 | 11:30 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
its diffrence in the gear box and also i the shifter arm outside the gearbox, when the tt have weights and extra long shift arms outside
Studio RSR
BMW //M
Aug 25, 2015 05:48 PM
The Oss
Aug 24, 2015 08:19 PM
