Unplugged Exhaust Valves
Old Jan 9, 2011 | 08:45 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
Like others have said.... the sport button when pressed only opens the valves at certain RPM's/conditions during acceleration.
If you want it open all the time, simply remove the sensor as shown in the link above. Very very easy to do and takes literally 10 seconds. The valves are energized closed....
However, another mod I have seen is a switch placed in the wiring harness. That way you can either use the OE programmed valve switching or you can use the switch and have it on all the time. I have heard of dealers installing the switch when requested and placing them in the cubby hole in front of the gear lever....
Jason
Old Jan 9, 2011 | 10:30 PM
bford100's Avatar
bford100 is infamous around these parts
"If you want it open all the time, simply remove the sensor as shown in the link above. Very very easy to do and takes literally 10 seconds. The valves are energized closed...."
Yes, exactly. This is why it is such a great little mod! It only takes a few seconds to disconnect and reconnect the sensor! You can have it either way!
Try it out, especially if you have a center muffler delete by Sharly, GMG, RSS or whomever, it just sounds great wide open with no vlaves opening and closing at different RPM's.
Old Jan 10, 2011 | 06:16 AM
Mr. B's Avatar
Mr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to all
Originally Posted by deputydog95
I currently have a center muffler bypass pipe installed. That was my first mod! Money well spent. The car sounds the way it should have from the factory.
So if I am understanding this correctly, by not unplugging the valve, the exhaust remains quiet from just above idle to 3k and then opens up when in sport mode?
Hardly seems worth it. If you are getting on it hard, you'll be well north of 5k the whole time anyway resulting in the "loud" setting. Considering there is a probably a little torque loss keeping the valve open in the low revs, I'm not sure its worth it. Porsche probably setup sport mode like that for a reason.
Meh... I'm leaving mine alone
I'm leaving mine alone too.
Mr. B
turbotuner20v
Sep 11, 2015 12:02 PM
Sep 10, 2015 03:20 PM
Money2536
Sep 1, 2015 04:56 AM
Ferrari
Aug 24, 2015 04:35 PM
