Unplugged Exhaust Valves
Old Jan 8, 2011 | 11:14 PM
bford100's Avatar
bford100 is infamous around these parts
Wow. Just unplugged the sensor that controls exhaust flapper valves. Now open all the timie. What an improvement in sound! Anybody esle done this and is there any benefits/drawbacks from this?
Old Jan 8, 2011 | 11:30 PM
SKXF430's Avatar
SKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud of
There might be a very slight loss of low end power but it is not really noticeable.
Are you running the stock exhaust? Or, do you have a bypass pipe?
Sounds even better when you run a bypass and there is no drone at all.
Old Jan 8, 2011 | 11:34 PM
bford100's Avatar
GMG x-pipe just got it. Sounds really nice, can't rev past 4K until broken in according to the "rules"!!! but right at 4K the sound is amazing!
Old Jan 9, 2011 | 02:26 AM
03-turbo911's Avatar
Senior Member
Yeah I've done that right after buying the RS! Sounds so much better without the valves.
Old Jan 9, 2011 | 11:57 AM
allans's Avatar
allans is infamous around these parts
Please describe procedure. Photos? Thanks.
Old Jan 9, 2011 | 12:17 PM
SKXF430's Avatar
Allan,
Takes less than 30 seconds.
Here is a link with pics.
http://forums.rennlist.com/rennforum...49-post27.html
Old Jan 9, 2011 | 12:47 PM
allans's Avatar
Done. Many thanks. I'll have to wait to see any difference - weather. My car is an 11 RS. Allan
Old Jan 9, 2011 | 01:12 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Why not just hit the sport button and open the valves? I don't understand this mod.
Old Jan 9, 2011 | 02:09 PM
bford100's Avatar
Sport button on opens flaps but not all the time, try it and you will see. My issue was that I always want more sound, and the flaps from time to time would get stuck closed on one side. I just don't like all this "flapping" and just want open all the time. My only question left is does this compromise any performance having them open the whole time. So far it is amazing and the sound is just what I want!
Old Jan 9, 2011 | 02:52 PM
h1sp's Avatar
h1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud of
Originally Posted by SKXF430
Allan,
for some reason i cant view rinnlist. Can anyone post up the photos here?
Old Jan 9, 2011 | 03:46 PM
I don't understand what you're talking about.
When my sport button is off, the valves open automatically at 4k. If you are running through the gears, you can hear a noticeable difference the volume once you surpass 4k.
When the sport button is on, the valves are open (loud sound) all the time. At least they appear to be. Even when its idling, you can turn the sport button on and hear the difference in sound.
So I don't really get the point if you can just hit the button. Maybe I'm not understanding this correctly.
Old Jan 9, 2011 | 05:22 PM
Izzone's Avatar
Izzone is a splendid one to beholdIzzone is a splendid one to beholdIzzone is a splendid one to beholdIzzone is a splendid one to beholdIzzone is a splendid one to beholdIzzone is a splendid one to beholdIzzone is a splendid one to behold
When you hit the sport button it opens the valves at idle.....then they close upon acceleration....and open back up at 4K
No sport buttin they just open at some an RPM higher than 4K
If you do not have a bypass pipe set up, I am not sure I would unplug them. The car has a drone on teh highway with them unplugged and no bypass pipe.
Moral of the story
step 1, call Alex and order bypass pipes
step 2, install bypass pipes
step 3, unplug valves
Old Jan 9, 2011 | 05:49 PM
drdrilz's Avatar
drdrilz is a jewel in the roughdrdrilz is a jewel in the roughdrdrilz is a jewel in the rough
Moral of the story
correct, except in sport mode "on" the valves open at 3k rpm vs 4k rpm for sport mode "off"
Old Jan 9, 2011 | 06:31 PM
Izzone's Avatar
I guesstimated the rpm.....I completed step one before I bought my car
Old Jan 9, 2011 | 07:22 PM
I currently have a center muffler bypass pipe installed. That was my first mod! Money well spent. The car sounds the way it should have from the factory.
So if I am understanding this correctly, by not unplugging the valve, the exhaust remains quiet from just above idle to 3k and then opens up when in sport mode?
Hardly seems worth it. If you are getting on it hard, you'll be well north of 5k the whole time anyway resulting in the "loud" setting. Considering there is a probably a little torque loss keeping the valve open in the low revs, I'm not sure its worth it. Porsche probably setup sport mode like that for a reason.
Meh... I'm leaving mine alone
