what exhaust 2 buy....
Old Dec 8, 2011 | 10:27 PM
  #61
kumar75150's Avatar
kumar75150 is infamous around these parts
I went back and forth between the Sharkwerks track and bypass. Alex recommended the bypass since I drive my car quite a bit and need it to be able to go through the In n Out or Chik Fil A drive through
Finally getting it installed next week.
Old Dec 8, 2011 | 10:46 PM
  #62
lopro's Avatar
lopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to behold
Question
Originally Posted by sharkster
Roger that;( Bummer! I could tell it was likely from china with the way the polish is;( Also keep an eye on that flange for the tips. It looks awful thing there and not enough welding on it;(
On the Sharky bypass:
Im currious why you guys dont just run it stright out tail pipes, Why the flange for the tails? As in why do you produce the bypass pipes so the tails have to be bolted on instead of just welding them without the flange?
Is it so you can retain the factory pipes, Use another style or for bracing to gain alittle extra strength???
im also not sure if this is asked before, Your pricing is the same for polished and black finish correct?
Ferrari
Aug 24, 2015 04:35 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
