Removal of Light and Ignition Switch on 997.2
Old Feb 16, 2011 | 05:42 PM
audiophilitis's Avatar
audiophilitis is infamous around these parts
I'm looking to upgrade the lower dash and glove box trim pieces to the OEM alcantara wrapped version sold at Suncoast. I've figured out how to remove the glove box cover and the passenger side trim, but the driver side piece is turning out to be quite a challenge.
Does anyone have instructions on how to remove the light and ignition switches? I've read somewhere that the light switch comes off by pushing it down and turning it clockwise -- just tried it and doesn't seem to work. It "clicks" and activates the light switch when pushed down and turned (instead of rotating the entire switch assembly. I'm a bit loathe to twist it further in fear of damaging the switch assembly (car is only 6 weeks old). The ignition switch, I have absolutely no clue.
I would appreciate any detailed instructions from anyone who has done this mod. I know it's a fairly simple mod -- just need some gurus to chime in.
Many thanks in advance.
Old Feb 16, 2011 | 05:47 PM
OmahaGT's Avatar
OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !
I did this mod myself and posted very detailed directions. MAcarbon has directions for the lights control. For the ignition, remove the plastic trim, then twist the plastic ring around the ignition left. My directions on this forum were deleted somehow. Here they are though.
Driver's side:
1. Remove light control unit. Remove trim. See MAcarbon website.
2. Remove ignition trim.
3. Remove carpet cover below side of navigation (One torx). Then pull it out.
4. Remove 2 torx screws holding leather cover for side of nav unit. Pull the leather cover toward back of vehicle. Don't force it.
5. Remove the plastic cover under the left air conditioning vent. Pop it out from the front of the dash. It folds into the back under the seals. Carefully pull it toward the rear of the vehicle twisting it outward slightly. Don't force it.
6. Remove lower instrument surround (above steering wheel/ under gauges). Position the steering wheel as low as possible, and pull the 2 drooping tabs up. It is very tight. It shouldn't break. Just don't damage other parts of interior when forcing it out.
Now all your torx screws for the lower dash are exposed. Start unscrewing the lower dash. There's 1 behind the lower instrument surround. There are 2 under the left air vent. A few under the dash. And, there are 2 more that were hiding under the nav side cover.
7. Pull the dash out toward you. There are electrical connections under there that need to be moved so don't yank it out.
8. Remove ignition (incredibly easy). There is a ring with rivets around the ignition. Take a flat head screw driver and twist the riveted ring left.
9. Unplug the ignition by pushing tab on plug and pull the plug. Use a screw driver to push tab.
10. Disconnect other plugs. One toward the back requires pushing multiple tabs.
11. The wires have ties that hold them down on the dash. They are just held down with rubber ***** in little holes in the dash. You should be able to keep all the ties usable. Just don't strain the wires too much when pulling them from the dash.
12. Remove the dash once electrical connections are undone.
13. Switch the foot light over. There are 2 tabs inside dash that help to push the light out the bottom.
14. Switch the trim over next to the foot light. It holds one of the electrical connections.
15. Put everything back in reverse order.
Google "alcantara lower dash install" for a little bit more info if needed. My directions on this forum got deleted somehow..
Old Feb 16, 2011 | 06:14 PM
OmahaGT's Avatar
It should be possible to remove the glove box cover without removing the whole lower dash.
1. With a small allen wrench, unscrew the dozen or so screws inside the glove box.
2. Remove the cover. Transfer over the silver glove box release.
3. Hold the silver release down, flush with cover, or it may lock shut. Replace cover.
4. Replace screws.
The trim piece to the right of the glove box just pops off.
Old Feb 16, 2011 | 06:22 PM
4. Replace screws.
I must be doing something wrong with the light switch -- followed MaCarbon instructions but the thing won't budge. The rest seems straightforward.
Thanks for taking the time to repost the instructions. You car looks great!
Old Feb 16, 2011 | 06:29 PM
OmahaGT's Avatar
Sure thing. Thanks, you have an awesome GT too. Push the light switch into the socket fairly hard, then when it is depressed, twist right. The lights shouldnt turn on. Good luck.
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
The Oss
Aug 24, 2015 08:19 PM
Ferrari
Aug 24, 2015 04:35 PM
