Anyone know whos GT3 this is? SCCA AUTOCROSS
Old Mar 2, 2011 | 09:07 AM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
If you know this car, any more info about the car/driver/location?
Old Mar 2, 2011 | 12:04 PM
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
I'm going to take a guess that it's Monty Pack. What are you trying to figure out specifically?
EDIT: Scratch that. Monty's car is silver.
Old Mar 2, 2011 | 02:24 PM
smf32s's Avatar
smf32s is infamous around these parts
I believe it is Gary Thomason whom is a past National Champ, if I am not mistaken. Not sure where it was shot.
Stu
Old Mar 2, 2011 | 06:47 PM
I want to ask him about his wheels setup. Those are CCW Classic. I hear they run 18x12 on NB 996. I'd like to know if those are 18x12 and the offset. If you have any info please let me know thanks guys!
Old Mar 2, 2011 | 08:25 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
CCW are great people to work with. Give them a ring.
Jason
Old Mar 2, 2011 | 11:01 PM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
Jason
+1.. Just call them
Old Mar 2, 2011 | 11:05 PM
Vandit's Avatar
Vandit has a spectacular aura aboutVandit has a spectacular aura about
SS = Super Stock class.
Old Mar 3, 2011 | 07:24 AM
loworbitsi's Avatar
loworbitsi is infamous around these parts
If the car is in Super Stock, the wheels have to be OEM sizes with a +/- of 6.35mm offset.
Old Mar 3, 2011 | 11:48 PM
ssgt3's Avatar
ssgt3 is infamous around these parts
Stu
Good eye - that is in fact my car, with the pic taken at the 2008 SCCA Solo National Championships held in Topeka Kansas. I managed to win the Super Stock class championship that year over 56 fellow SS competitors in Vipers, Corvette Z06's and Lotus Elises.
I did not run the car at the Nationals in 2009 or 2010, but will run it this year again. SS allows cat back exhaust (I run a Cargraphic), shocks (Moton), and any alignment, but pretty much everything else has to be stock spec. Those are CCW Classics in the stock sizes. I have however considered taking the car to a class that allows considerably more modifications (ASP), so I also would be very interested to hear backspace specs for a 18x12 rear that will clear everything......
Old Mar 4, 2011 | 01:37 AM
Good thing I found you. I wanted to ask you about your CCW Classic. Because I talk to John (CCW) and said that 18x12 +63mm with 8.98" backspacing is used on GT3's alot. I'm interested in the wheels. But I have to call him back because it has a different fitting on regular 911, like mine. I would like to run 18x12 but will settle with 11 or 11.5. By the way since your CCW Classic has the stock specs, would that be 18x11?
Do you have anymore pictures of your car with the CCW Classic? You can email it to me at sweat2breathe@yahoo.com. Thanks man!
Old Mar 4, 2011 | 06:06 AM
loworbitsi's Avatar
...and any alignment...
Are you allowed to run shims in SS?
Old Mar 4, 2011 | 12:29 PM
ssgt3's Avatar
The 996 GT3 has pretty much the same body as your car, with the main relevant difference here being that I'm pretty sure the GT3 fender lips are rolled slightly more than yours. Was John talking 996 GT3 or 997 GT3? Unless you are racing yours I would probably just stick with 18x11. The 8.5 and 11" 996 GT3 wheel offsets like mine should bolt right on. I want to run a 315/30-18 rear tire, which is a little better on a 18x12.
Here is a better pic of the wheels:
Old Mar 4, 2011 | 12:41 PM
ssgt3's Avatar
Yes - because of the way shims are described in the shop manual, they are legal in SCCA stock class competition. Ironically, a subtle difference in the language used in the manual means rotating the strut tops is not legal in stock. Also not legal is the alternate adjustable control arm caster bushing that really should be used with the shims, so caster goes way up if you add much shim. The only real problem with that is reduced tire clearance in the front of the wheel well.
The V710 really only wants about -2.2 camber in front (Hoosiers need more), so you can get close to that in a GT3 without shims.
Old Mar 4, 2011 | 12:43 PM
loworbitsi's Avatar
I know that in Appendix F of the rule book, there's specifics that say that the rotation of the tops are NOT legal. But good info on the shims, and the rest of the setup.
albert@velosdesignwerks
Sep 9, 2015 04:17 PM
GT3/GT2/GT Vendor Classifieds
Sep 9, 2015 03:55 PM
997 Vendor Classifieds
Sep 9, 2015 03:51 PM
997 Turbo Vendor Classifieds
Sep 9, 2015 03:49 PM
996 Turbo Vendor Classifieds
Sep 9, 2015 03:48 PM
