997.1 GT3 RS wing vibrate problem
Old Apr 3, 2011 | 08:40 AM
M-Rufus's Avatar
M-Rufus is infamous around these parts
Question 997.1 GT3 RS wing vibrate problem
Hi guys,
My rear wing at speeds above 130Mph vibrates a little bit, i can see it doing that in my rear view mirror. At lower speeds its does not vibrate.
I have already checked all the bolts fixing the wing and they seem very tight.
Do i have to increase the angle of the wing for speeds above 130 mph?
All you guys out there with a .1 GT3 RS can give an input about yours, please ?
Thanks.
Old Apr 3, 2011 | 08:52 AM
sjgreco's Avatar
sjgreco is a name known to allsjgreco is a name known to allsjgreco is a name known to allsjgreco is a name known to allsjgreco is a name known to allsjgreco is a name known to all
Maybe its the review mirror.
Old Apr 3, 2011 | 01:15 PM
M-Rufus's Avatar
Nice one.
I don´t think so.
Old Apr 3, 2011 | 02:22 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
I am just going to throw out a random guess and say at those speeds the vibration from the high speed turbulent air is probably normal. Like watching an airplane wing vibrate as it moves through the air. Its probably normal.
Jason
Old Apr 3, 2011 | 06:15 PM
M-Rufus's Avatar
Jason
Yeah Jason.
I think it has to do with that too.
That´s why i ask to 997.1 GT3RS users if they have the same vibration in the wing at those speeds.
Old Apr 4, 2011 | 07:36 AM
TurboDogue's Avatar
TurboDogue is just really niceTurboDogue is just really niceTurboDogue is just really niceTurboDogue is just really niceTurboDogue is just really nice
139 yesterday on inyterstate and no noticeable movement on mine. Will try again this weekend for you 2007 RS.
Old Apr 4, 2011 | 11:03 AM
M-Rufus's Avatar
Thanks TurboDogue.
So, you did not have any kind of movement or vibration from the wing, it was just still ?
Just want to make sure that everything is ok and a second opinion from members with the same car is always nice to read.
Thanks.
Old Apr 4, 2011 | 11:08 AM
chardonet's Avatar
chardonet is infamous around these partschardonet is infamous around these parts
Maybe your entire decklid is loose? Just a thought if the wing is bolted down tight as you stated....
Old Apr 4, 2011 | 01:37 PM
M-Rufus's Avatar
That does not move an inch, the only vibration is on the carbon wing.
Although i checked every bolt securing the decklid and wing.
Thanks for your input.
Old Apr 4, 2011 | 01:41 PM
M-Rufus's Avatar
I was thinking that it could be some strong wind at that time, but already tried with a low wind situation and it still vibrates a bit. The vibration is not sideways, it´s a up and down. Any more 997.1 GT3 RS users could give your input ? Thanks.
Old Apr 4, 2011 | 03:49 PM
napier's Avatar
napier is infamous around these parts
It could be resonating, try taping a small mass around it and see if it gets rid of it.
Old Apr 4, 2011 | 09:22 PM
playboymd's Avatar
playboymd is infamous around these parts
Talking At 165 mine is moving for sure
It starts to vibrate about 120mph and gets really bad at 165mph
This is normal / I'm on my second GT3rs
Old Apr 4, 2011 | 11:15 PM
GT3 Chuck's Avatar
Administrator
I have an old (2005) 996 GT3 with the factory RS cf wing and no vibration at all up to 160mph with 4 deg shims...the brackets that are glassed/riveted into the wing might be loose...some guys have removed those brackets by drilling out the rivets and then attaching some other brackets...is the wing oem or one you got from someone else?...the newer wings are adjustable I believe whereas mine uses shims....that may be why the newer ones are vibrating
Old Apr 5, 2011 | 12:42 PM
M-Rufus's Avatar
Thanks for you input.
Thank for your input also, but your wing has a different fixing in the bootlid and it can´t be comparable. Thanks anyway.
Old Apr 19, 2011 | 04:46 PM
M-Rufus's Avatar
Any more help from other members ?
Thanks.
werkzrs
Apr 23, 2020 12:03 PM
MrNurse
Sep 10, 2015 09:44 AM
MrNurse
Sep 2, 2015 07:03 AM
Vrseis
Aug 20, 2015 07:41 AM
