4.0 Intake on 3.8
Old Jan 4, 2012 | 08:34 PM
m5trol's Avatar
m5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud ofm5trol has much to be proud of
4.0 Intake on 3.8
Does it make sense to put the 4.0 intakes on a 3.8L RS? I am just thinking out loud and wondering. What do you guys think?
Old Jan 4, 2012 | 09:06 PM
OmahaGT's Avatar
OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !
It looks cool. I don't think you would see any performance improvement at all.
Old Jan 4, 2012 | 09:23 PM
GT3 Chuck's Avatar
Administrator
most likely just a loss in gas mileage as the computer supplied more fuel to compensate for a slightly leaner mixture...if the motor was built like US FINA motors with restricted intakes and exhausts it could make some difference combined with a less restricted exhaust...but these motors are pretty much maxxed out stock..I doubt if even a tune to optimize a/f ratio would squeeze enough to make it worthwile....if you do it please document it well with dyno before and after
Old Jan 4, 2012 | 09:34 PM
OmahaGT's Avatar
Hmm. I switched to the 3.8 RS box on my 2007 GT3. I should probably remap.
Old Jan 4, 2012 | 10:03 PM
GT3 Chuck's Avatar
Administrator
I don't see any need unless the stock air box was more restrictive than the intake, which I doubt...even tho the box may have less restriction than your stock air box and provide a cooler air charge the intake is the same as it was before and will only pass so much air...shouldn't upset your a/f ratio at all
Old Jan 5, 2012 | 07:11 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
too costly for nothing gained
Old Jan 5, 2012 | 05:12 PM
scbra's Avatar
scbra is infamous around these parts
the latest magazine I got detailed really well all the R&D Porsche did on the 4.0. I believe the bigger intake only worked on the larger motor. Other than looking cool, I have no idea why spend $4k on a carbon fiber box intake.
Oct 2, 2015 02:23 PM
