Hesitation in power delivery between 5k-6k?
Old Jun 9, 2012 | 10:52 PM
madporsche85's Avatar
madporsche85 is infamous around these parts
Once I give a full throttle from 2nd gear, I get a hesitation in acceleration between 5,000-6,000rpm. Actually, the RPM shortly goes down in the range @ WOT. If I gently control the gas pedal though, the symptom doesn't bother me. Besides the range I mentioned, my 07 GT3 runs great without any power loss or hesitation.
Is it caused by bad MAF? Any ideas?
Old Jun 10, 2012 | 10:42 AM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
MAF, could be but it sounds like a fuel delivery issue. Maybe your fuel pump is going but I'm just guessing.
Old Jun 10, 2012 | 02:39 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
What's your rev limiter set at? That will cut fuel delivery when you hit it.
Old Jun 11, 2012 | 11:40 AM
bumperpip's Avatar
bumperpip is infamous around these parts
check codes first, THEN panic.
Old Jun 12, 2012 | 12:00 AM
No codes, no fuel cut
Can GT3's racing gear ratio cause the issue?
Old Jun 12, 2012 | 12:11 PM
Wayne K's Avatar
Wayne K is infamous around these parts
VarioCam ?
Sales@RSW
Sep 3, 2015 09:34 AM
gulf gt
Aug 27, 2015 10:27 AM
