GT3RS "fuel trim" adjustment
I own an orange 2007 RS.1. I have a Sharkwerks rear exhaust bypass, otherwise box stock. 15,400 miles. Plugs never replaced, air filter brand new (old filter fine). Street driven only. Perfect overrev history. I am observing one side (drivers) white and dry in color, the other sooty dark. My dealers "reader" is broken, awaiting replacement unit from Germany. Tech says "fuel trim" related. Questions: Are there adjustments for each side independent of the other side for fuel trim (mixture?)? Any other ideas what could be causing this? Thanks in advance for your learned and insightful advise.
Now I have the full M&M race exhaust with no valves on, both pipes are the same nice shade of grey
RAudi Driver, yes I checked that they were both still properly connected - not sure about if both operating properly. Any way to easily check this out? Can I have someone cycle the Sport button, and/or rev the engine while I observe? Will the valves operate w/o load and merely revs? Thanks for the info?
That's why I went for a full valveless exhaust
Are you referring to the vacuum activated valve that opens in sport mode? If so, I unplugged the connector to cause it to be open all the time (what can I say? I love the noise!). I am not sure how/if that would effect the variation in the tips.
