From someone who DIYs their BMW M3 entirely, is the 997 GT3RS as DIYable?
Old Jan 8, 2013 | 02:06 PM
bimmerfan08's Avatar
bimmerfan08 is infamous around these parts
Thanks for the replies so far guys. Based on what has been said I feel component that a GT3/RS is DIY-friendly. More advice is always appreciated.
Old Jan 8, 2013 | 08:23 PM
djantlive's Avatar
Plugs are a pain on the gt3. Oil change takes longer on dry sump.
Neither will stop you. Just giving you an idea, that's all. Unlike m3, the Porsche has a lot more oil and service interval is much longer.
Old Jan 8, 2013 | 08:26 PM
DT007's Avatar
DT007 is infamous around these parts
No issues w/ maintenance... The hardest part will be changing wheels on a 997.2 w/ the center lock!
Old Jan 9, 2013 | 02:20 PM
monochrom3's Avatar
monochrom3 is infamous around these parts
Good to know, as I just made the jump myself and DIY'd most stuff on my e46 M3.
Old Jun 17, 2013 | 03:51 AM
AEsco48's Avatar
AEsco48 is infamous around these parts
Originally Posted by AudiOn19s
As has already been stated you will be fine. These things are a little cramped but well designed to be pretty easy to work on. I'm a big DIY guy and also came from an M3 and had zero issues adapting
I've done everything from small projects to the full engine pull (without lift) to do both my coolant fittings as well as light wight flywheel and clutch. No problems with any of it. Actually one of the bigger pains in the rear is a simple plug change but it just takes some patience,universal joint and a few lengths of extensions and you will be fine.
You used a jack to drop the engine?
Old Jun 17, 2013 | 03:27 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
You will be fine DIYing a GT3.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Jun 17, 2013 | 05:57 PM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
Originally Posted by bimmerfan08
. Anyhow, I've considered ownership of a 997 GT3RS (.2 preferably) as my next performance car sometime in the next decade..
Though you should be fine but it is not un-usual for motor skills to regress with age and who knows what happens in the next decade
Old Jun 17, 2013 | 08:36 PM
///s62e39's Avatar
///s62e39 is infamous around these parts
You'll be fine. I was very surprised at how easy the 997s are to wrench on.
Old Jun 23, 2013 | 04:51 PM
AudiOn19s's Avatar
AudiOn19s is infamous around these parts
Motorcycle jack, yes
Old Jun 23, 2013 | 07:15 PM
AEsco48's Avatar
Fantastic!
I secretly cant wait to drop my engine at some point after I get a GT3... Hopefully its for preventative maintenance.
What type of resources did you have to do the work? I have not seen even a small amount of DIY guides as we had for the E46 M3. Are the Porsche workshop manuals available for the .1 GT3?
I am also coming from two E46 M3 (02 and 04) that I did all the work on...
echo220
May 12, 2016 04:11 AM
alevine
Nov 4, 2015 10:05 AM
tommyboy214
Aug 26, 2015 10:49 AM
Aug 21, 2015 09:56 AM
