Brembo Rotor Upgrade Experience
Old May 16, 2013 | 03:11 PM
vividracing's Avatar
One of our customers recently ordered the Brembo Iron Tyoe III Rotor Conversion with Performance Friction Brake Pads for his 997 GT3 and we thought his experience, questions, and pictures would be good for others to reference. Once this customer recieved his Rotors, he noticed that the hardware seemed loose. This was the customer's question to our sales guy.
"The Brembo rotors and PFC brake pads installed fine. One question on the rotors. I noticed that some of the hardware that secure the discs to the aluminum hats appear to be “loose”, but a printed sheet in each shipping carton said not to tighten the hardware. Were the rotors assembled by Brembo? Attached are several photos to show that the hardware appears to be tightened a different amount depending on the location of the fastener on the hat. I don’t want to run the car at track speeds if the rotor hardware is installed incorrectly. Is the brake torque on the discs carried by the fastener hardware?"
This is question is more common than one would think. We reached out to our friends at Brembo to see what the exact protocol is and what a good explanation for our customer would be. Here was his response,
"Do NOT to touch those bolts! That is the way they are supposed to be. Here is a paragraph from the FAQ section on our www.racetechnologies.com web site: Some of the bushings in the two-piece disc assembly seem to be loose."
"The two-piece disc assemblies utilize a floating disc. The mounting system of the disc is designed to allow a specific amount of float in both the radial and axial directions. Brembo has engineered special springs that are used on every other fastener in order to slightly preload the assembly. This has been done to prevent excessive noise from the system during street use, while still maintaining the benefits of a floating disc. These springs can be seen when looking at the backside of the disc. The small screws on the backside of the disc are properly torqued during assembly and utilize thread lock compound to prevent loosening. They must not be tightened further."
This a great lesson for anyone new to Brembo or those who are trying their hand out at the two-piece rotor set. If you have any question about a fitment or install, call or email our sales office! Check our more of our Big Brake Kits and Brake Parts.
Old May 21, 2013 | 10:07 AM
a_Y's Avatar
a_Y
a_Y has a spectacular aura abouta_Y has a spectacular aura about
Thanks!
Also this is a very nice looking 997.2 GT3 with 5 lugs conversion! May I know what kind of wheels are on the car? Are those BBS LM?
Old May 21, 2013 | 10:40 AM
I believe they are BBS LM-R. See here - http://www.vividracing.com/catalog/w...762.html?r=323
Old May 23, 2013 | 12:44 PM
ckiesz's Avatar
ckiesz is infamous around these parts
Thanks for posting. I had the same question when I did my brembo upgrade. Their design works very well. Just the right float without the noise.
Old May 30, 2013 | 03:26 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
I get a ticking noise from the rotors that can only be heard when driving close to a side barrier. I wouldn't say they're quiet .
Old May 30, 2013 | 03:28 PM
I bet you that is a rock in the tire.
Old May 30, 2013 | 03:32 PM
eurotom's Avatar
Uh I wish it were thy simple it's coming from both sides of the car. Keep you posted after inspection
Old May 30, 2013 | 06:33 PM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
Thanks for clearing that up. Very important topic as I'm sure many people who switch to two piece rotors would be concerned if they noticed that. As far as the GT3 pictured, the wheels are Fiskse FM10 and I agree it does have a great set of mods.
Old Jun 3, 2013 | 07:11 PM
ckiesz's Avatar
Haven't heard any clicking from mine, but the car spends all its time at WOT or hard on the brakes. Usually the dreaded noise associated with floating rotors is a howl or groan from the disc going into occilation, which I've not had.
Good luck with your search
Old Jun 5, 2013 | 02:49 AM
Tmhk's Avatar
Tmhk is infamous around these parts
Why change to 5 lugs?
Old Jun 6, 2013 | 06:35 AM
monochrom3's Avatar
monochrom3 is infamous around these parts
I've got these on the front and do hear the same slight ticking noise when driving near a wall. Can only hear it when the windows are down and from the side of the car closest to the wall. No complaints though.
Old Jun 6, 2013 | 11:04 AM
Misanors4's Avatar
Safer, easier to use, more wheels available, etc... If it ain't broke, why fix it?
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
bhart192
Aug 29, 2015 06:20 AM
Steven997TT
Aug 27, 2015 02:56 PM
