GT3 RS - Understeer
Old Jun 20, 2013 | 12:06 AM
sraz786's Avatar
sraz786 is infamous around these parts
GT3 RS - Understeer
Folks,
My diff went bad and recently had the Cup Car clutch pack installed on a 2011 RS. I am perceiving much more understeer than before. Normal? Tips on driving through it? If you have done the same, what are you perceptions? Thanks in advance.
Old Jun 21, 2013 | 04:22 PM
AZ997TT's Avatar
AZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to behold
Turn in or exit?
Try softening your front sway bar one hole.
Old Jun 22, 2013 | 12:02 PM
sraz786's Avatar
Originally Posted by AZ997TT
Turn in or exit?
Turn-in.
Sway bar is set to softest setting it can be on.
Old Jun 22, 2013 | 12:13 PM
AZ997TT's Avatar
try one off full stiff on rear bar.
How much front camber you running?
A more agressive camber, say 3 degrees plus will really wear your tires out on the street, so play with the bars first.
jeremyr4
Sep 17, 2015 06:00 PM
