Are my MPSC tires due for replacement?
Old Apr 8, 2014 | 01:34 AM
Exacc's Avatar
Exacc is a jewel in the roughExacc is a jewel in the roughExacc is a jewel in the roughExacc is a jewel in the rough
Sorry for the Newb question...I am not too sure, but is it time to replace these tires?
The front still looks ok...
ID:	356680   Click image for larger version
Old Apr 8, 2014 | 07:26 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
In my opinion, for the street driving in the rain, I'd say the rears need replacing. Else, have fun with them for a bit more miles..........
Old Apr 8, 2014 | 10:21 AM
Exacc's Avatar
would one replace when the wear bars are reached? Or when the wear bars are erased?
Still felt like it had a lot of grip in my last twisty road driving...but that's probably the outside of the tire working and not the inside...
Old Apr 8, 2014 | 01:32 PM
512bb's Avatar
Technically when you hit wear bar it tells you that you are at a certain thread depth so the tire should be replaced. However, going past those makes the tire effectively more like a slick. Again, not a good idea to drive in rain, but the dry weather grip may even be better depending on tire construction and compound and on these tires the grip should actually increase.
On my GT3, I was running a bit more camber and would check them often and would only change when I would see steel threads starting to show at the inside of the tires.
Old Apr 9, 2014 | 12:51 AM
groupagst's Avatar
groupagst is infamous around these parts
Just got a set of MPSS to replace my cups. The way to go if you're doing more street than track.
Old Apr 13, 2014 | 09:28 AM
YellowDragon's Avatar
YellowDragon is infamous around these parts
This is what mine looked like when replaced...
Currently having Bridgestone RE-11s
Old Apr 14, 2014 | 11:59 AM
wpgfordguy's Avatar
wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !wpgfordguy Is a GOD !
Wear bears are the indicator of legal limit in most places ( Usually 2mm) if they are close you are through the useable street life of the tire.
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
L.A.P.
Aug 23, 2015 11:48 PM
John@SpeedTech
Aug 23, 2015 12:07 AM
