Your 2010/2011 GT3 alignment specs please
Old Aug 27, 2014 | 09:04 AM
Nurburg611's Avatar
Nurburg611 is infamous around these partsNurburg611 is infamous around these parts
Running on 19" stock wheels with Pzero Corsa. No spacers. Driving about 80% street / 20% track.
I'll probably max out on negative camber in front under stock suspension, neutral/slight toe out in front, slight toe in at rear. Caster 8 deg stock.
That said, would be great if you could post your aligment spec sheets with the exact figures so I can use as template.
Thanks a lot
Old Aug 28, 2014 | 04:50 PM
STALKER's Avatar
STALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to beholdSTALKER is a splendid one to behold
I'd like to know what ppl are running as well.
My 2010 GT3 is arriving next week.
Old Aug 28, 2014 | 10:11 PM
ChrisEVO's Avatar
ChrisEVO has a spectacular aura aboutChrisEVO has a spectacular aura about
-2.5 fr / -2.0 rr. 3/16 toe in rear. Very slight toe out in front. Front and rear bars at middle setting to start. Adjust per track. Even tire wear in front. Slight inner wear acceleration in rear. Car is very neutral even at the limit. Probably drive 70% street / 30% track.
Old Aug 30, 2014 | 10:26 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
-2.2 F
-2.5 B
Med-soft front
Hard - back
1/16 out front
3/16 in back
Conservative street/track setup 7.1 Gt3
Old Sep 1, 2014 | 08:52 PM
RedRSA's Avatar
RedRSA is infamous around these parts
Originally Posted by Etchhead
-2.2 F
-2.5 B
Med-soft front
Hard - back
1/16 out front
3/16 in back
Seems beyond conservative on the rear. Most recommend -1.8 to -2.0 degrees max camber on the rear, even with Hoosiers. Haven't heard of many that use more camber rear than front.
Old Sep 2, 2014 | 01:35 PM
Nurburg611's Avatar
Thanks for all the replies. My toe is set for 1/16 out front and 3/16 in back but I can't get the camber to go beyond -1.7 deg in the fron so I did little less in the rear. Do you guys use spacers to increase negative camber beyond 2.0? Is stock maxed out at -1.7 or is my suspension just screwed up?
Secondly, I feel like it's really easy for my alignment to be knocked out of place. Every time I go in for setup, the beginning values differ vastly from the last setting. I can't even recall any events that would impact the alignment so drastically.. Thoughts?
Old Sep 2, 2014 | 06:36 PM
jakegt3's Avatar
jakegt3 is infamous around these parts
Your suspension is not screwed up. There is a limit to how much negative camber you can get without modification. Lower control arm spacers will allow you to get the camber more negative than -2.0. You can get them from Tarett (http://www.tarett.com/items/996-997-...him-detail.htm) and maybe other places.
I also found my alignment was constantly going off, but this was with lots of track time. First thing to try is aftermarket rear toe links (Tarett has these). I also ended up replacing most of the rubber in the suspension with solid bushings and/or monoballs. The rubber deteriorates with age and stress, which contributes to alignment creep.
Jul 29, 2019 11:13 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
