Changed brake pads and now a clunking sound
Hey guys just changed my brake pads and get a clunking sound when I brake at low speeds of go from reverse to forward and then hit the brakes. Doesn't happen every time, maybe every 4th or 5th brake application at lower speeds. Is it possible the pads are shifting inside the caliper? I used OEM pads and bought new springs and retaining pin and torqued to 21 or 23 ft/lbs.
Checked the springs (hand through the wheel) and it's tight...
It sort of sounds like the clunk you get when you turn your wheels completely to the side and hit the stop.
Any ideas?
It sort of sounds like the clunk you get when you turn your wheels completely to the side and hit the stop.Any ideas?
It is possible for brake pads to shift in the calipers and make a clunking noise. I had it happen this past spring after installing aftermarket pads. Sounded like the suspension was falling apart when driving over expansion joints and ripply roads. Turned out the pads were a mm or two different than oem and the tensioner springs needed to be adjusted/modified to securely hold them. Should have been a couple hundred dollar deal but before we figured it out we disassembled the suspension and replaced the camber plates and shock mounts (which were shot anyway) so it turned out to be quite a bit more. You should probably disassemble and reinstall the pads and if that doesn't cure it, then figure out what's going on with the springs. GL
I may take the spring and pin off and bend the spring to make it tighter.
I tried this and didn't help...
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
