996 gt3 oil change?
It's pretty straightforward as far as oil changes go. The biggest pain in the *** is draining the sump as the oil comes out of that FAST and will splash everywhere if you aren't prepared for it.
I believe there are DIY guides on Rennlist and RennTech but again, its very straight forward.
As for the filter, I usually pull it partway out and let it drain for a while, then hold a shop rag under the filter “neck” while I pull the filter out, not so bad.
yup...
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
