Planning on buying 2015 GT3 please help
Old Dec 28, 2015 | 08:42 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Dave, how does it take a while to lift the car. In mine, the nose lifts in about 2 sec or less.
Old Dec 28, 2015 | 09:37 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
Same here...about 1-2 seconds. Also, if you do not have the lift you will find you drive the car less. For example, I would not have been able to drive to work since the garage I park in can only be accessed with the lift. For me it was all about having more places to drive to maximize driving time.
Old Dec 29, 2015 | 12:20 PM
superflysteiny's Avatar
superflysteiny is infamous around these parts
Hi guys I am new here and I own a 2015 gt3. I think the front lift depends on your experience driving lowered cars. Sounds crazy and I am a little embarrassed to admit this but owning several very low trucks and cars I found it very easy to get used to how low this car sits. But if you want piece of mind I would suggest you get the lift.
Old Dec 30, 2015 | 01:41 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Agreed on the lift time. It less than 2 seconds. The old version on the 997 was slower, but not that much.
Old Dec 30, 2015 | 09:27 PM
DAVE W's Avatar
DAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to behold
2 seconds is an eternity when you have a line of cars behind you pulling into a lot or garage....and around LA most the scrapes are through intersections and road transitions, where there is no way you are stopping for a full 1-2 seconds before proceeding. Not saying its not useful to have, just saying that I wouldn't rule out a car based on the one option as its not a perfect solution and you are going to scrape with or without it. but that's 1/2 the fun...
Old Dec 31, 2015 | 09:29 PM
Nikolas's Avatar
Too funny. If you can't anticipate, what do you do for braking? The system activates up to 30 mph. It's not like you need to stop and then activate.
Old Jan 1, 2016 | 12:45 AM
lowpue's Avatar
Exactly, I was wondering what all the fuss is about...I was trying to understand the problem with a couple of seconds of rise time. :-)
Old Jan 1, 2016 | 04:05 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
Get the front lift, you will use it a lot more than you think
Old Jan 3, 2016 | 11:31 AM
AWZR1's Avatar
AWZR1 is a name known to allAWZR1 is a name known to allAWZR1 is a name known to allAWZR1 is a name known to allAWZR1 is a name known to allAWZR1 is a name known to all
I have a 2015 with no lift.
It is very flat around where i live but steep driveways at work---have never scraped, just need to take it slow and at an angle.
Plastic replacement splitters are only $150 @ suncoast
SHIFT
Feb 24, 2016 09:21 AM
'Trust'
Jan 9, 2016 04:44 PM
exclusive
Dec 25, 2015 12:20 AM
boconnor811
Dec 21, 2015 08:37 AM
