Supreme Power's Porsche 991 GT3 RS w/ 19" BBS E88 Wheels, BBi Center Section Exhaust
Old Dec 4, 2017 | 02:00 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 1
Supreme Power's Porsche 991 GT3 RS with 19" BBS E88 Wheels, BBi Center Section Exhaust, BBi Roll Bar
We would like to share this beautiful White Porsche 991 GT3 RS that already have a set of 19" BBS Motorsport E88 Wheels and our BBi StreetCup Roll Bar roll bar installed at Supreme Power. As the car was due for service, our mutual client Chris J. brought the car over to us to perform an oil change and swap out the secondary center mufflers with our BBi Center Section Exhaust. Here are some pictures that we would like to share and stay tuned for updates.
Vehicle Specifications
  • BBi Autosport StreetCup Center Section Exhaust
  • BBi Autosport StreetCup Roll Bar w/ Optional Reinforcement Gussets
  • BBS E88 Wheels 19 x 9.5 & 19 x 12.5 Wheels Gold Face
  • Toyo 265/35/19 & 345/30/19 Tires
BBi Roll Bar Installed at Supreme Power
BBi Autosport Porsche 991 GT3 StreetCup II Bolt-In Roll Bar (With Optional Gussets)
Features
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in USA
Next, we will swap out the secondary center mufflers with our BBi Center Section Exhaust To reduce weight and deliver a more aggressive exhaust note.
BBi 991 GT3/RS Center Section Exhaust with Optional Black Ceramic Coating
Made in the USA, the new exhaust is TIG welded out of brushed T304 stainless steel and features the main pipes merging in the middle to function as an x-pipe. For those who desire a slightly milder exhaust tune, this piece is a great alternative to our Cup-style Side Muffler Bypass Pipes. By retaining stock side mufflers and valves, the factory "sports button" feature is kept to conveniently switch back and forth between the aggressive "sport" mode during spirited driving sessions and the quieter, more civil "non-sport" mode for minimal noise on the highway.
Key Features
  • Delivers deep aggressive exhaust sound
  • Significant weight reduction
  • Retains Sports Exhaust Button function
  • TIG welded T304 brushed stainless steel construction
  • Factory primary side mufflers & catalytic converters are all retained
  • Direct bolt on replacement
  • Fits all 997 & 991 GT3/GT3RS models
  • 50 State 100% emissions legal
  • Will not void warranty
  • Optional black ceramic coat finish available
  • Made in USA
Some beauty shots without in raw stainless without the ceramic coating to highlight the craftsmanship
BBi StreetCup Center Section Installed
- jerry@bbiautosport.com
About Supreme Power Inc
1562 Kimberly Ave
Fullerton, California, CA 92831
Highlights info row image
(714) 632-1951
www.supremepower.com
International shipping is available and wholesale inquiries are welcomed. BBi Autosport products are also available worldwide through our growing dealer network in North America, Latin America, Europe, Middle East, Africa, Asia and Pacific. BBi Autosport is always actively working to expand our dealer network worldwide to grow the distribution of our products and better serve our growing client base.
- Jerry@BBiAutosport.com
