997.2 PASM dampers and axle lift issue
Old Jan 23, 2019 | 07:39 AM
Bovien's Avatar
Bovien is infamous around these parts
I have just replaced my .2 PASM dampers with new. Taking a slow ride around the block, my axel lift system kept lifting. Button responds to lower the car and raise it, but the system also raises it by itself almost immediately.
Now the small connectors from the damper; I'm guessing they are only for the PASM function? Their plugs seemed to fit in both ways. No apparent guiding pin or anything? I can't activate the dampers PASM function.
Also, I have had the battery disconnected, so I have a PASM failure at startup. This usually goes away after a short drive, which I'm not able to do due to winter and road salt here in Denmark. Could this result in activating axle lift until they 'settle'?
Lastly, I have had the axle lift system down to replace a pressure switch. However this system doesn't really have anything I can think of that would result in it activating by itself. No plugs that can be reversed, and the switch I replaced is only for sending the pressure at full lift, and that works perfectly.
Any ideas?
nitrorocket
Jul 3, 2016 09:18 PM
MONKY LONDON
Sep 28, 2015 07:16 AM
abt cup
17
Jul 30, 2011 07:41 AM
frafoss
May 31, 2009 09:47 PM
