Cargraphic Kit 2
Old Nov 25, 2006 | 05:34 PM
LTCJMRamos's Avatar
LTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud of
Cargraphic Kit 2
Anyone have any info/experience with this Cargraphic kit?
http://www.cargraphic.de/stepone/dat...it_GT3_2_2.pdf
Dyno chart seems somewhat "optimistic" showing 411 hp (302 Kw) and 317 ft-lb (429 Nm) at the wheels. My stock GT3 dyno'd 322 and 230 at the wheels, respectively, which equates to about a 15% drivetrain loss. So, Cargraphic is claiming 90 rwhp and 80 ft-lb from their kit.
I realize that the type of dyno they used could have a significant impact.
Old Nov 26, 2006 | 06:05 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
It's not 411 rwhp. It's 411 hp at crank...
Old Nov 26, 2006 | 09:57 AM
LTCJMRamos's Avatar
Is Cargraphic not being honest about this? A dyno chart shows hp at the wheels and not the crank.
Old Nov 26, 2006 | 10:28 AM
Kaizu's Avatar
Usually tuners in Europe use crank hp and not wheel hp. Many tuners are using engine dynos so they get the right numbers (that's imho a good way...at least every car I've seen with high numbers on engine dyno is as fast as it should be in real life conditions...)
Old Nov 26, 2006 | 01:21 PM
LTCJMRamos's Avatar
Duh!! Engine dyno. I'm so used to thinking of chassis dyno only, didn't even think of that. I've emailed Cargraphic to confirm. Thanks
Small Shrimp
Sep 1, 2015 10:51 AM
Steven997TT
Aug 27, 2015 02:56 PM
Vrseis
Aug 20, 2015 07:41 AM
