Brake Fluid 997 GT3
Old Apr 17, 2007 | 02:23 PM
sasportas's Avatar
Awaiting Email Confirmation
sasportas has a spectacular aura aboutsasportas has a spectacular aura about
Brake Fluid 997 GT3
What are you guys running for fluid? SRF / Motul. The SRF is silicon I think - is this bad for the seals?
Old Apr 17, 2007 | 02:47 PM
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
Castrol SRF
Old Apr 17, 2007 | 05:26 PM
frayed's Avatar
frayed is infamous around these parts
Couldn't agree more.
Old Apr 17, 2007 | 05:35 PM
TCM's Avatar
TCM
TCM is infamous around these parts
The SRF cannot be mixed with any other fluid if an emergency pops up. Which makes me always suggest the Motul 600. That being said, both are great alternatives.
Old Apr 17, 2007 | 08:22 PM
G996's Avatar
G996 is infamous around these parts
SRF CAN be mixed....
Just read the can.......
Old Apr 17, 2007 | 10:53 PM
TCM's Avatar
TCM
I personally spoke with a Castrol rep about this 2 years ago and he advised heavily against mixing the fluid as it can gel up. Maybe they have changed their forumla?
Old Apr 18, 2007 | 04:08 AM
03-turbo911's Avatar
Senior Member
Heard the same thing and that's why I don't use it.
Old Apr 18, 2007 | 07:04 AM
mishref's Avatar
mishref is infamous around these parts
I just ordered a couple bottles of SRF .. 1 liter for flushing .. one for top up.
Old Apr 18, 2007 | 07:11 AM
930man's Avatar
930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future
remember SRF has to be changed 18 months after install!!! i would sugest every 12 months.... i use it in cup car and street GT3... never a problem and never blead brakes while using it
Old Apr 18, 2007 | 07:56 AM
sasportas's Avatar
Brake Fluid
Thanks for the input. I have always run ATE Blue - but noticed that I still needed to bleed fairly frequently. I'm curious about the Motul 600 - is this a step up from the ATE Blue?
Old Apr 18, 2007 | 09:49 AM
tdf360's Avatar
tdf360 is infamous around these parts
Definitely. Personally I don't think the added cost of the SRF over the Motul is justified by the performance. Most drivers even on tracks that are tough on brakes will not see any difference. Just my opinion.
Gary
Old Apr 18, 2007 | 10:02 AM
frayed's Avatar
Gary, a bottle is what, 80 bucks and you drive a $250,000 car?
SRF is the best stuff out there, its wet boiling point is superior to all others, and for non racers, this is exactly the most critical parameter. Dry boiling points are important for those that completely flush their brakes before every track event. I certainly don't do that.
More info
http://www.swedishbricks.net/700900F...Comparison.htm
An extra 50 degrees of protection is not trivial.
And, the worse the driver, typically the tougher he is on brakes. And, if you are running PCCBs, they tend to run pretty hot; added protection is defiintely a plus.
For the ultimate setup, fresh Castrol SRF with a complete flush done the old fashion way: two person bleed. This technique provides a better, stiffer pedal than any of the pressure bleeders or vaccum bleeders. And the speedbleeder type devices can be a nightmare; I'd skip those.
Old Apr 18, 2007 | 10:38 AM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Any benefit to using this stuff on non-track cars (PCCB) or is it overkill?
Old Apr 18, 2007 | 11:22 AM
frayed's Avatar
Really, really doubtful. You cannot detect a difference in brake feel from one fluid to the next (ignoring silicones which are compressive) until you get a lot of heat into your brakes, heat from track use or from slowing down on the Autobahn from 180 mph to 30 mph. In other words, it's almost impossible to really heat load your brakes on the street.
I wouldn't mess with the factory fill unless you go to the track.
Old Apr 19, 2007 | 09:43 AM
tdf360's Avatar
I probably shouldn't have mentioned price, I will just emphasize I have never had any fade with Motul. And I paid $177k.
Gary
