Wheels Weight Comparison!
Old Apr 1, 2004 | 03:36 PM
HKE46Boy's Avatar
HKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really nice
Factory GT3 Wheels
18" x 8.5" ET 40 24.91 lbs
18" x 11" ET 63 27.34 lbs
Kinesis:
8.5x18" 20 lbs.
11x18" 22 lbs.
Fikse:
8.5x18" 20 lbs.
11x18" 21 lbs.
HRE Competition:
8.5x18" 18 lbs.
11x18 19.5 lbs.
BBS 1-piece Manthey Magnesium
9x18" ~15.5 lbs.
11x18 ~18 lbs.
Old Apr 1, 2004 | 04:24 PM
retsel75's Avatar
retsel75 is infamous around these parts
GT-3 wheel weight comparison
Although there is a significant unsprung weigh difference over factory stock GT-3 wheels, if you buy a spare stock set, they are warrantied for two years. I drive the car to all the DE events and the factory wheels can handle the pot holes and road hazards far better than the other manufacturers you noted.
Old Apr 2, 2004 | 10:24 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
tyson and i are condsidering Cargraphic racing mesh at 16/17 # roughly F/R.
it's a trade off -- but GT2 wheels are roughly 4-5 # PER WHEEL heavier than gt3 wheels so the decision to take the breakage risk is even greater potential payoff.
i am am testing some fikse 13's profils on my gt2 over the next few weeks, courtsesy of Jack, and we'll see how much difference 28# less unsprung makes on my very bumpy mountain roads
Old Apr 2, 2004 | 11:02 AM
Turbo Racer's Avatar
Turbo Racer is infamous around these parts
I have 19" kinesis f110 one piece forged:
Available in 19 x 8.5 (18 lbs) and 19 x 11.5 (20 lbs)
pretty light.
anyone know what the SOLID turbo twists weigh (did a search and laid a goose egg)
Old Apr 2, 2004 | 12:08 PM
luting_chen's Avatar
luting_chen is infamous around these parts
for the new HRE lightweight series...
do you guys know if the Brembo 15inch brake will fit?????
I'm thinking about either getting 15inch 8 piston....or the racing version 15inch 4 piston ones.....
Old Apr 2, 2004 | 03:02 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
More like 34 lbs of less unsprung weight than those boat anchors you're running.
Old Apr 2, 2004 | 03:09 PM
Jack(LA)'s Avatar
Moderator
The C4S and early Turbo's "solids" weigh in at ~ 26 and 31 lbs, front and rear, respectively. The GT2 wheels (which are also solid spoke and wider) weigh another 2 lbs per wheel more than the Turbo's.
Old Apr 3, 2004 | 03:34 AM
HKE46Boy's Avatar
Yes, I've seen some one from other board running HRE C21 with 15" kit!
Old Apr 3, 2004 | 10:23 AM
Jack, thank you. Looks like my car lost 34# all together . now if I could do the same
Old Apr 3, 2004 | 12:11 PM
Jack(LA)'s Avatar
Moderator
You're welcome.
BTW, that's 34 lbs of unsprung weight, which would require you to lose about 90 lbs or so to equal that weight savings.
Old Apr 3, 2004 | 10:31 PM
thanks for the good news Jack
Old Apr 12, 2004 | 07:39 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
You're welcome.
Jack,
Please explain this to me further. I'm a novice but I know what a weight change will do.
Old Aug 13, 2004 | 12:25 AM
Falgo's Avatar
Falgo is infamous around these parts
Unsprung Weight is a term used to describe that part of a vehicle's mass that is directly connected to the wheels, and not isolated through the suspension.
Because this part of a vehicle is in direct connection to the road and therefore subject to all of its imperfections, it is important that this weight be as low as possible, or at least much lower than the weight of the sprung part of the vehicle, in order that the wheels maintain optimal contact with the road surface. The greater the unsprung weight, the greater the inertia of the suspension, which will be unable to respond as quickly to rapid changes at the interface between the road and wheel. Unsprung weight can be reduced by using light alloy wheels, independent rear suspension (where the weight of the differential is not part of the unsprung weight).
Old Aug 13, 2004 | 02:29 AM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
Are the HRE competitions actually available yet? I thought they were still working out the Ti bolt issue.
Old Aug 14, 2004 | 07:33 AM
Falgo's Avatar
Official release date is Oct 1st!
