Are the PCCB vs. Standard brakes the same size on the GT3/RS?
Old Jun 28, 2007 | 06:59 AM
damon@tirerack's Avatar
Moderator
There's been a bit of confusion on my end and I thought you guys might be able to weigh in and help clear the confusion. We have yet to see a PCCB equipped GT3 (In northern IN, imagine that.....) so I'm hoping for your help to help build 18" race fitments. Thanks.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jun 28, 2007 | 07:09 AM
GTS-R's Avatar
GTS-R is infamous around these parts
I am pretty sure the PCCBs are 380mm front 350mm rear and the steel brakes are 350mm front and rear. This applies to both the GT3 and RS models.
Old Jun 28, 2007 | 07:38 AM
DM1's Avatar
DM1
DM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond repute
I've also heard that GT3 and RS brake sizes are the same.
Old Jun 28, 2007 | 09:02 AM
A430v's Avatar
A430v is infamous around these parts
Just checked some technical literature...this man is correct. PCCBs 380 mm front, steel 350 mm front. Rears 350 mm for both versions. Cheers!
Old Jun 28, 2007 | 09:19 AM
jhbrennan's Avatar
Correct - here's the GT3 and RS tech info.
2lflat4
Nov 18, 2019 05:05 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
