Brake fluid longevity
Old Apr 19, 2004 | 07:41 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
I have 8K miles on my GT2. Does anyone have any thoughts about the OEM brake fluid. Alternatives? How often does it need to be changed? I plan on tracking the car about six times a year.
Old Apr 19, 2004 | 08:45 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
I think at a minimum Porsche recommends changing the fluid on the 15,000 mile service or every two years.
Old Apr 19, 2004 | 09:25 PM
TCM's Avatar
TCM
TCM is infamous around these parts
It varies depending on how you use the car (harder use usually requires more flushes). There are some great aftermarket fluids out there such as ATE SuperBlue, ATE Type 200, Motul 600, or Castrol SRF. The Castrol SRF is the best fluid available but is expensive and cannot be mixed with anyother normal DOT4 type fluid or it will harden into a gel. I suggest Motul 600 or ATe SuperBlue to all of my clients. They can be mixed with normal fluids in emergencies and provide enough temp resistance for most "sane" drivers.
Old Apr 20, 2004 | 09:48 AM
Larry Herman's Avatar
Larry Herman is infamous around these parts
If you're tracking the car, change your fluid every 3 months. Brake fluid can absorb enough moisture in that time frame to possibily lower the boiling point significantly. For the street, every 2 years is usually sufficient.
Old Apr 20, 2004 | 09:59 AM
Code Red's Avatar
How difficult is it to change the brake fluid?
Old Apr 20, 2004 | 10:05 AM
With a commercial bleeder, quite easy. Without one, a pain & you're better off with 2 people to do it. One to operate the brake pedal, and one to open & close the brake bleeder nipples. You should empty the master cylinder reservoir first so that you start with clean fluid. I built a vaccum bleeder years ago, and it takes longer to jack up the car & remove the wheels than it does to change the fluid. It attaches to the bleeder screw & just sucks the fluid through.
Old Apr 20, 2004 | 11:57 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
Larry,
what does "in the paint shop" mean?
Old Apr 20, 2004 | 12:02 PM
MetalSolid's Avatar
MetalSolid is infamous around these parts
Factory Paint Shop - stick a fork in it.
Old Apr 20, 2004 | 12:03 PM
It means that the body is built, and it is being painted. After that, they assemble it, drive the ***** off of it for 20 miles & put it on the boat. Hopefully it will be here by early June.
Old Apr 20, 2004 | 01:36 PM
watt's Avatar
ah thank you. i like carrara white
noel,
what does "stick a fork in it?" mean. you guys are giving me a real education today!
Old Apr 20, 2004 | 01:43 PM
MetalSolid's Avatar
It's an American term, "stick a fork in it, it's done"... ergo Porsche have done cooking the paint on Larry's car.
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
