Need help in reading my E-gear report
Old Oct 14, 2009 | 04:32 PM
bosco42's Avatar
bosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to behold
Can anybody help me read the report I received on the e-gear on a car I'm interested in
Old Oct 14, 2009 | 07:26 PM
RedGTS's Avatar
RedGTS is infamous around these parts
What is your question exactly? At the top of the snap it should tell you the difference between the closed clutch position now and when it was new, and you have around 7-8mm to use if I recall correctly. So if the difference between the two positions now is say 1mm, the car has used around 1/7th or 1/8th of the clutch.
Old Oct 14, 2009 | 09:02 PM
bosco42's Avatar
Yes ...it says 18.4 when new and 18.2 now ...diff of -0.2
But the report has many other things also (4 pages)....does this report show the over revs or is that another report that I need?
Thanks very much
Old Oct 15, 2009 | 07:17 AM
RedGTS's Avatar
Thanks very much
Well it sounds like the clutch is pretty much brand new, but I don't know much about all the other data. I've never heard of the e-gear snap showing overrevs though-my guess is that would be in a different report.
Old Oct 15, 2009 | 02:02 PM
Gasman's Avatar
Gasman is a jewel in the roughGasman is a jewel in the roughGasman is a jewel in the rough
I agree. I think the overrevs would come from the LDAS data.
Also does an e-gear car overrev? I thought the ECU would prevent that?
Old Oct 15, 2009 | 04:55 PM
bosco42's Avatar
You are right he sent me the LDAS report afterwards.....can still over rev if you are shifting manually with the paddles
Old Oct 15, 2009 | 05:02 PM
Ag02M5's Avatar
Ag02M5 has a spectacular aura aboutAg02M5 has a spectacular aura about
I doubt that as it is electronically controlled. The computer will not let you select a gear that will put you past redline. Going up, the rev limiter obviously keeps you from going over.
From my discussion with techs...what it does tell you is information about time spent at redline and last time it hit it.
Old Oct 15, 2009 | 05:10 PM
Gasman's Avatar
That's what I've heard as well. The egear won't let you downshift into a gear that would cause an overrev.
With E-gear, it is impossible to make a gear selection (in any mode) that will result in over-rev or gearbox damage. This means an e-gear will always be a safer long term used buy IMO, as it's impossible to crash gears, over-rev the engine and generally abuse the car. The manual (shiny stick, very phallic, can't miss it, also sold as a paper weight! ) has no such safe guards and requires driving properly to avoid damage. E-gear is more 'idiot' proof, but comes with it's own quirks, as you'll know. "
Old Oct 15, 2009 | 05:14 PM
Ag02M5's Avatar
I don't think that is quite true either.
There is a rev limiter going up on most manuals so SOME safe guard.
However, it can't protect an over-aggressive downshift or a missed upshift with a lower gear pull.
The rev limiter won't save you from mechanical overrev.
Old Oct 15, 2009 | 05:17 PM
Gasman's Avatar
That quote, I think, is saying that in a true manual you can't protect from overrev like an egear will.
Wait, I see what you are saying, the rev limiter will protect you somewhat, but only if you are revving up. That is true and like you said with a true manual you won't protect with the wrong downshift.
Last edited by Gasman; Oct 15, 2009 at 05:19 PM. Reason: i figured out what was being said.
Old Oct 15, 2009 | 05:18 PM
Ag02M5's Avatar
Agree. All good.
Edit: Hope I didn't come off like a ******. Just trying to be helpful.
