Macan First Drive Impressions - Motor Trend and Autoweek
http://www.motortrend.com/roadtests/...an_first_ride/
http://www.autoweek.com/article/2013...NEWS/131009813
Autoweek spills more details on engine specs:
We first found ourselves in the heavily contoured passenger seat of the Turbo Macan that is set to lead the Macan line-up. It is powered by a twin-turbocharged 3.6-liter, direct injected gasoline V6 engine that, up to now, has only been offered in naturally aspirated guise. The adoption of forced induction, a complex cooling system fed by those substantial front air ducts and other associated internal modifications as raised output by a significant 100 hp, bumping it to 395 hp – the same figure touted by the naturally aspirated 4.8-liter V8 used in the Cayenne GTS. There is an even bigger increase in torque, which climbs by 110 lb ft to a sturdy 406 lb ft. By comparison, the most powerful Q5, the SQ5, uses a supercharged 3.0-liter V6 direct injection gasoline engine with 354 hp and 347lb ft.
Weight?
Weight?
Porsche is yet to reveal any weight figures for its new model but Woehler suggests a number of weight saving measures, including the use of aluminium in the body, will see the Turbo hit the scales at under 3750lb. Nevertheless, there are sufficient power reserves to provide it with more than just brisk performance. In lower gears it possess serious pace away from the lights and truly impressive in-gear acceleration. Final performance numbers are yet to be validated. Our money is on a 0-62mph time in the sub-5.0sec bracket and a top speed above 160mph. Sufficient to bury the SQ5, for sure.
Another review and a new interior picture, some of the details are known already but there are some new as well:
http://www.bdlive.co.za/life/motorin...-excited-about
IF WE had any worries that the all-new Porsche Macan SUV wouldn’t be a "real" Porsche, they quickly evaporated following a few minutes in an early prototype with one of the brand’s test drivers at the wheel.
Barrelling into a sharp bend just outside Los Angeles, Hans-Juergen Woehler, a development engineer for Porsche SUVs, brakes hard — harder than you’d expect any SUV could. Yet he turns in smoothly, stamping on the throttle in the exit and correcting a gentle slide. The lack of body roll, the agility and the playfulness are hallmarks of the 911, Cayman and Boxster, but here they are in a 4,600mm-long SUV.
We rode in a car on the standard steel springs and one on optional air-suspension (the Turbo has this as standard), and both felt firm, but in a grown-up way. In short, it rides like a Porsche.
The optional air-suspension system is the best choice for those who think they’ll take their Macan over challenging terrain. Any heavy off-roading is out of the question — there are no differential locks or low-range gears — but cars with this can at least be raised by 40mm to get over outlying rocks or muddy fields. They can also be lowered by 45mm from the standard height to make loading heavy items into the boot easier.
3WDistributing
31
Oct 27, 2017 01:26 PM
r_matt_6
Oct 8, 2015 06:07 PM
'02996ttx50
Aug 26, 2015 08:41 PM
PelicanParts.com
Macan Vendor Classifieds
Aug 26, 2015 04:51 PM
Thanks for sharing.
