LET Motorsports - Stage II Tuned E55 AMG
Old Apr 18, 2009 | 07:38 AM
MLR's Avatar
MLR
MLR is infamous around these parts
Many thanks go out to Tony, Jerry & Wayne all of LET Motorsports and EuroCharged Performance in Plainfield, IL (letmotorsports.com) Their superior customer service and vast knowledge clearly showed through and they were by far, the best tuners I have worked with.
I recently purchased an E55 AMG that was bone stock and babied. I started researching the 4-5 tuners that were available to the Benz world and was pleasantly surprised to find LET Motorsports in IL. Not only did they seem to be the best rated tuners for my ride, but they were only 20 minutes from my house.
Now onto the Parts & the Results of my Family Saloon...
PARTS
  • Johnson CM30 Intercooler Pump - (This is a great upgrade to the stock Bosch pump. Flows three times amount of fluid, lowers IAT's more efficiently than the stock pump. Quicker recovery time.)
  • Custom Stage II LET Tune by Wayne @ LET
  • 172mm Crank Pulley
  • Version 2 Water Pump Pulley
  • New Supercharger Belt
DYNO Results - Mustang Dynamometer @ Performance Autowerks
First run was with the stock ECU Flash and the parts listed above.
446 Torque
360 WHP
Second Run was after the custom tune and the gains were very nice for a Mustang Dyno.
463 Torque +17 gain
391 WHP +31 gain
Last edited by GT3 Chuck; Apr 18, 2009 at 10:36 AM. Reason: remove non-sponsor link
Old Apr 18, 2009 | 09:10 AM
DFW911T's Avatar
DFW911T is infamous around these partsDFW911T is infamous around these parts
Good work!
If you add headers (even shorties) I bet you'll pick up another 20 to 35 on both counts. You've tweaked the cooling, now let it breathe better.
Old Apr 18, 2009 | 11:02 AM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
Why were your stock numbers 360WHP?? That is crazy low, stock should be around 400-414WHP.
Old Apr 18, 2009 | 12:43 PM
MLR's Avatar
MLR
The Mustang & Dyno Dynamics are both "heart breaker" Dyno's, but they are the best to tune on. To be honest, I was expecting to be at least 400 + whp, however I try not to put to much stock in the actual numbers that are released, but try to focus on the gains of before and after as the car sits on the Dyno. Most people tend to be more impressed by some inflated number (like Dyno Jet numbers), but tuning a car while it sits on the Dyno is the only way to get accurate readings for modifications.
I was also told by LET, that this particular Dyno reads low and to not be disappointed by the low reading numbers. All I can say is the car is pretty quick and is driving very well with this current set-up...Next mod will be next week (larger heat exchanger).
jyupitt1
Sep 23, 2015 06:26 AM
maniatis
New Member Introductions
Sep 2, 2015 04:37 PM
PelicanParts.com
Aug 21, 2015 01:37 PM
