My first 996 Oil Change
Old Nov 29, 2007 | 09:57 AM
Alicia's Avatar
Alicia is infamous around these partsAlicia is infamous around these parts
My friend is going to let me put the old girl up on his lift tonight so that I can perform a long overdue oil change. I've done oil changes before but not on this car. I know it takes about 9quarts and that it's pretty simple (I did a 6speed search). Anything else you think I need to know?
Mobil1 0W-40 should do it right?
Old Nov 29, 2007 | 11:40 AM
lax01's Avatar
lax01 is infamous around these parts
Righty-Tighty, Lefty-Loosey?
Old Nov 29, 2007 | 12:51 PM
deckman's Avatar
Have a look here for Loren's complete how to: http://www.renntech.org/forums/index.php?showtopic=7055
Old Nov 29, 2007 | 01:04 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
the 996 is pretty easy, just be careful, the filter can get messy since its a canister type and have a BIG drain can.
Old Nov 29, 2007 | 01:54 PM
deckman's Avatar
And if you have a new drain can that has a vent tab, make sure the vent is open before the oil begins to drain into it! Don't ask.
Old Dec 7, 2007 | 10:23 AM
Alicia's Avatar
well the change went pretty smoothly until it came to fill it up. I put in 9 quarts and the dip stick read at the mimimum mark. The digital oil gauge said I had about 3/8 fill. It was all very wierd. After a few days it started registering more and more and now the dip stick reads at the full mark.
Old Dec 10, 2007 | 07:54 AM
GarnetRedCoupe's Avatar
GarnetRedCoupe is infamous around these parts
I am not sure about the 996 but I think the principal is the same.... When I change the oil I do the sump first and then the engine. After it drains completely, I empty the used oil into larger (4 qts?) oil jugs to measure how much came out so I know how much to put back in. Also, you can get a sample of your engine oil and mail it for an analysis to make sure you don't have any premature engine wear and they let you know how much longer or shorter you need to make your oil changes.
COBB Tuning
Jan 1, 2025 09:02 AM
pshep138
Sep 1, 2015 09:45 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
