Mini Cooper Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
M7 Speed Bull Bar & Clutch $50 Gift Card More !
Old Jun 30, 2016 | 09:19 AM
ECS Tuning - BMW's Avatar
ECSTuning
M7 Speed R60/61 Countryman / Paceman Bull Bar
M7 Speed offers a 100% bolt-on Bull Bar kit for the R60 MINI Cooper Countryman & R61 Paceman.
The 2” diameter main bar comes with an integral mount for two large 8” diameter driving lamps. The kit includes the 2” diameter steel bull bar, all mounting brackets and all hardware needed for an easy DIY installation.
No modifications to the vehicle are required. No cutting, no drilling and no welding!. Made in the USA. Now available at ECS.
Mess with the MINI and get the bar.
Fits:
R60 MINI Countryman /S/SX(All4)/JCW (2011+)
R61 MINI Paceman /S/SX(All4)/JCW (2013+)
Click HERE to shop!
ECSTuning
ECS MINI Jack Pad Adapter / Pads | R50-R59 MINI
Take the danger and aggravation out of lifting your MINI with the ECS Tuning Jack Pad Adapter. Designed to fit the head of a standard floor jack, the adapter has a rectangular head that firmly engages the chassis jack pads.
Positive engagement at jack head and chassis resists jack slippage and shifting, while the raised adapter head prevents damage to rocker panel trim and underbody panels.
Made of black anodized aluminum for added strength and corrosion resistance, the adapter fits the head of most hydraulic floor jacks, including the excellent Schwaben Low Boy.
Lift Easy!
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW (2005-2008)
R53 MINI Cooper S/ JCW (2002-2006)
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE to shop!
ECSTuning
R56-R59 MINI Cooper Rear Sway Bar Awareness
ECS now offers an array of aftermarket large diameter sway bars, each designed to better decrease body roll through turns and wandering at highway speeds.
Reduce body roll in turns, stiffen suspension, and add a much needed dimension of handling predictability - each kit is designed to fit and function in perfect harmony with your car.
Fits:
Click HERE to shop!
ECSTuning
South Bend Clutch Options |MINI R53 R52
Do you plan on bringing your MINI’s engine output to the next level? The wisest enthusiasts build their drivetrain to match powertrain advances. The best place to start is with the clutch.
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. With four stages accommodated for, you can be sure to find the exact clutch for your needs.
From daily driven to track cars they have you covered.
$50 ECS Gift Card and Free shipping, Clutch Winner!
Keep the power under control
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S/ JCW (2005-2008)
Click HERE to shop!
ECS Tuning - BMW
Mar 22, 2016 06:52 AM
ECS Tuning - BMW
Mar 22, 2016 06:27 AM
PelicanParts.com
Mar 21, 2016 03:29 PM
C.Plavan
Track & Autocross
Jul 18, 2003 07:01 PM
